Re: Rear axle seals leaks. Please report.
Just found this thread the other day, discovered that both rear axle seals were leaking at 37,000 miles or so. Right one was leaking onto the brake rotor; left one was just seeping. Neither were bad enough to leave oil on the driveway.
Called the dealer, dropped it off Sunday, both seals replaced Monday. I'm thinking of doing the axle vent mod and being done with it. I'm not sure I want to run as much hose into the body as was mentioned in the other thread though. I'm thinking just a good 2 feet or so should be fine with a filter on the end.
