Old 08-29-2007, 01:17 PM   #15 (permalink)
cneary812
cneary812's Avatar
Re: OEM Class 4 hitch quote from dealer!
Originally Posted by 54warrior
18mm = .7086"
11/16 = .6875"
17mm = .6693
It was an 18mm bolt, the 11/16" wrench just happened to fit it better I assume. Not many new vehicles have ANY standard size fasteners on them, if they do, it's rare.
...and on a side note...
I wish our country would just switch to the metric system and be done with it, it's so much simpler.
Im not sure what the reason was but I started it off with an 18mm socket and it was fine till i put the torque wrench on it and it slipped off so I switched to a 11/16 socket and it worked like a charm.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is offline   Reply With Quote
