I'm referring to the saws for stock height app, with the adjustable lift set at max lift... nice though, I'm almost certain my ideal setup would be the DR front coilover hat flipped and set at 4" over stock height total lift and still use a spacer to get some preload if possible, with the PRG upper control arm so I can get more droop and a deavor for the back, even without consulting greg I've come to my own conclusion... I'd still buy DjAlex's set if I could get the cash soon enough, but probably can't so I'd settle for spending more and getting what may be best for what I'm looking for
soft cushy ride better than stock (OR equiped/rancho shock) offroad abilities
I'm sure either would fit, but with the amount of lift I want to use, I think the DR would work better, plus I like the black spring and arm as opposed to red...
