Re: Quick 2* Timing ????
Yes there has been conflicting report on this. I have since learned the timing advance is located in the Eprom section of the ECU, it will not change unless you change it with the Consult or Cipher (or similar software). The timing advance will be lost if the dealer should ever reflash your ECU with new/updated file.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
