Thread: Nitrogen
Old 08-31-2007, 01:08 AM   #3 (permalink)
RobKar
RobKar's Avatar
Re: Nitrogen
^^^HAHAHAHAHAHAHAHAHAHAH ROFLOL .... ^^^
OK for a quick answer... Use Nitrogen because it does not expand when heated and the molecules are bigger so less air escapes from the tire.
Longer answer:
Nitrogen is a nonmetal, with an electronegativity of 3.0. It has five electrons in its outer shell and is therefore trivalent in most compounds. The triple bond in molecular nitrogen (N2) is one of the strongest in nature. The resulting difficulty of converting (N2) into other compounds, and the ease (and associated high energy release) of converting nitrogen compounds into elemental N2, have dominated the role of nitrogen in both nature and human economic activities.
At atmospheric pressure molecular nitrogen condenses (liquifies) at 77 K (−195.8 °C) and freezes at 63 K (−210.0 °C) into the beta hexagonal close-packed crystal allotropic form. Below 35.4 K (−237.6 °C) nitrogen assumes the alpha cubic crystal allotropic form. Liquid nitrogen, a fluid resembling water, but with 80.8% of the density, is a common cryogen.
Unstable allotropes of nitrogen consisting of more than two nitrogen atoms have been produced in the laboratory, like N3 and N4.[1] Under extremely high pressures (1.1 million atm) and high temperatures (2000 K), as produced under diamond anvil conditions, nitrogen polymerizes into the single bonded diamond crystal structure, an allotrope nicknamed "nitrogen diamond."[2]
TrollopInTraining™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
