If you have the lower gearing of the Big Tow or Off Road pkg. the performance hit won't be as bad. But until there are aftermarket gears I won't get anything over a 34, and then pick the lightest brand if all else is similar.
Originally Posted by Titan1080
I went from the 245/75/17 Bridgestone stockers to LT285/70/17 BFG MTs which are approximately 14 lbs heavier per tire. The stockers were about 31.5 and the MTs are an even 33 according to BFG. Even with that small of a change I still noticed a decrease in power which I feel I got back with the K&N77 CAI. Until I got the Magnaflow, the Titan felt like it was stock as far as power is concerned.
Tirerack says the MTs are 50 lbs. Is that the number you have? My ATs KOs are 58lbs, in the same size. So I've considered those because of the weight savings.
Originally Posted by helomech
I got the toyo 295/70-17 mt's, and now it will downshift going up some hills that it would downshift before. I also go into a situation in some mud that it would not climb out of in 4 hi, before it would have spun all the tires easily. I had to use 4 low to get enough power to the tires to climb out.
Darnit! I see that you have the lower gearing. That's the other tire I'm considering .... I estimate them at about 75lbs. I found them on the Canadian Toyo site where they didn't have the weight listed.
