Old 09-04-2007, 05:10 PM   #20
bighitter
bighitter's Avatar
Re: Roadmaster Active Suspension = AWESOME!
The RAS acts as a rear sway bar so that makes a rear sway kind of redundant and it does a good job as a rear sway bar. I am still going to pick up a better front sway bar as well.
Shouldn't be any problem with that, it is pretty easy, just read through it a couple times and make sure you understand it so you don't waste time doing things redundantly. I would say it really takes about an hour to hour and a half doing it yourself with a lift or good set of jack stands and jacks.
bighitter is offline   Reply With Quote
