Originally Posted by t2green1
Ok guys .... need your help/experience. What is the max tow rating on a 2008 Titan w/o the factory tow package? At what point do you need to switch from a class III to a class IV hitch? At what point do you need an equalizer hitch or a sway bar? When should you get a brake controller? Any and all help is greatly appreciated. New to towing, so looking for advice. Thanks.
I have a 2005 CC SE without the tow package. I just went to uhual and bought a class 3 hitch installed with all the wiring, relays, draw bar and ball for around $360. Plus they give you lifetime warranty for $5 bucks.(which is included) I posted a thread on here. My truck can pull 7400# without a tow package. I know when I get around 6000# I will buy a WD hitch. I dont think you need to switch from a Class 3 to a Class 4 becuase if you get the WD hitch it will level your truck out and make it a lot easier for you to pull more weight. Tekonsha is a great brake controller from what I hear. I just ordered mine. I was told for long huals use a brake controller or when road conditions are not upto par.
