Go Back   Nissan Titan Forum > Titan Discussion > Buy/Sell
Buy/Sell Got some parts or a truck you need to sell? Need to find something? This is the place to look.
If you are unable to find a used car here, you may try our Used Car search engine at the following URL: Used Car Search, or simply put your Zipcode into the following box and a direct search will be done in your area.
Old 10-17-2004, 07:12 PM   #1 (permalink)
50CC Factory Race Dirt bike FS
2004 50CC Factory Race Dirt Bike FS
Hi Guys,
I have two Kaseas MXR 50CC factory race bikes for sale specs:
Engine 2 stroke single-cylinder Franco Morini. Light alloy cylinder with highly-dimensioned 5 scavenge ports, chromium-plated liner and carbon fibre reed valve
Displacement cmc. 49.8
Bore and Stroke mm. 39x41.7
Compression Ratio 11.8:1
Carburator Dell'Orto PHBG 19
Max Power Output 12.8 hp a 11,000 rpm
Ignition: CDI
Fuel Pre Mix
Starting System Kick-starter
Gearbox Single speed with 3 Shoe automatic clutch
Exhaust System Giannelli racing-type with aluminium muffler
Frame Single steel beam frame
Front Suspension Marzocchi Magnum 32 mm. hydraulic telescopic fork
Rear Suspension Paioli adjustable oleo shock absorber
Front Brake 0 175 mm. disc brake with hydraulic master cylinder and caliper
Rear Brake Foot operated hydrolic disc brake
Front Wheel Spoked, E -12 x 1.50
Rear Wheel Spoked, E -10 x 1.50
Front Tire 3.00 -12 cross
Rear Tire 3.00 -10 cross
Wheel Base mm. 940
Dimensions length 1,440 mm., width 290 mm., height 950 mm.
Saddle Hieght cm. 70
Dry Wieght kg. 41
Fuel Tank Capacity 4.2 litres
This Bike retails at 2500 and is the same as a KTM Pro Jr that sells for 3000
IM selling for 1600 brand new I have two Available or trade for dirtbike or quad. PM me or email me at perez909@charter.net Great gift for Kids
Thanks
Turbobladz is offline   Reply With Quote
Old 10-25-2004, 09:22 PM   #2 (permalink)
bump need to sell, christmas is comming up!
