Originally Posted by ARMADAinSMOKE
Sounds like the seller is stating that the spring has a stiffer rate so it doesn't compress like an OEM spring would. This is how he gets the truck to be "lifted" 2.5".
That would be an INSANLEY stiff spring !!! Spring rates are measured by the amount of weight it takes to compress the spring 1" ... so on the non-offroad titan ... with a factory 500# spring rate that compresses say 3" on each side (that's 1500# per side being applied) ... so 3000# ... to make the spring compress 2.5" lessthan 3" ... you would need .5" of compression ... so take 1500# weight per side and you need to compress it 1" to find the spring rate ... so the spring rate would need to be ....
3000# spring rate PER SIDE ... That would ride so insanely rough (and would cause breakage somewhere I'd bet).
I think NOMike had an idea that would eliminate spacers (I'm all for that), but didn't understand the issues caused by the Daystar spacers.
A 1" taller spring with the factory spring rate would raise the truck 1" ... a 1" taller spring with a slightly higher spring rate (say 650-750#) would net about .5" for a total of 1.5" but would ride stiffer ... still not 2.5" and still risking coilover destruction.
2008.5 Nissan Titan SE CC 4x4
RF with Buckets
Black Grill
Chrome Mirrors and Handles
Medium Tow Package (everything but gears)
Line-X with Ducks Unlimited Logo
15% Tint All The Way Around
Llumar Paint Protection
20" Enkei TSP1's
305/55-20 Toyo OC AT
Bilstein Adjustable 5100 Fronts at 1"
Bilstein 5100 Rears
Magnaflow Duals
Garmin Nuvi 660
Cobra 75-WS XT
3' Firestik
Serving as a Tow Rig for my Jeep Cherokee ...
