Go Back   Nissan Titan Forum > Titan Discussion > Buy/Sell
Buy/Sell Got some parts or a truck you need to sell? Need to find something? This is the place to look.
If you are unable to find a used car here, you may try our Used Car search engine at the following URL: Used Car Search, or simply put your Zipcode into the following box and a direct search will be done in your area.
Old 04-05-2005, 02:36 PM   #1 (permalink)
Extended Modified Lowering Shackles
I have one set of the modified stock shackles that has been extended 2" inches. These are what I have on my truck to lower the rear. These shackles along with the helper springs will give you about a 2" inch drop in the rear. Used alone will give you about 1 1/4" to 1 1/2" drop. Cost is $60.00 plus shipping. I should have another set soon. THESE WILL REQUIRE THAT 1" INCH LIP UNDER THE BED TO BE GROUND DOWN OR BENT OVER. THEY WILL NOT FIT UNLESS YOU TEND TO THAT LIP.
extended-modified-drop-shackles-attachment.jpg  extended-modified-drop-shackles-new-picture-titan.jpg
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 04-05-2005, 03:20 PM   #2 (permalink)
Are they a simple bolt on application? Of course minus the 1" lip. What exactly do you mean by tending to the lip.
Chris
hvyjnkr is offline   Reply With Quote
Old 04-05-2005, 03:53 PM   #3 (permalink)
By tending the lip I mean you have to grind it down or bend it over flat. These replace the stock shackles. These are original Nissan stock shackles that have been extended.
Old 04-05-2005, 08:50 PM   #4 (permalink)
I also can make them extended only 1 3/4" inches.
Old 04-06-2005, 04:37 AM   #5 (permalink)
Got any idea how much it will cost to ship them to knoxville tn.? And how would you accept the payment?
Chris
Old 04-06-2005, 08:23 AM   #6 (permalink)
Shipping would about $8.00 and any payment will do.
Old 04-06-2005, 03:18 PM   #7 (permalink)
Is that C.O.D.? Pay before or after receit of product. I am very interested
Chris
Old 04-06-2005, 06:14 PM   #8 (permalink)
I'll ship them out to you and after you receive them you can send the money. That's the way I've been doing it and it has worked OK. That way you get to look at them before you pay.
Old 04-06-2005, 06:51 PM   #9 (permalink)
How does the 15th of the month sound to you? Will you still have some sitting around?
Chris
Old 04-06-2005, 07:11 PM   #10 (permalink)
I might. Would you want the 2" I'll send you a private message with my Email address.
Old 04-07-2005, 04:38 AM   #11 (permalink)
Sounds great. Which ones do you have on your truck?
Chris
Old 04-07-2005, 07:15 AM   #12 (permalink)
I have 2" inch ones on now.
Old 04-12-2005, 09:18 PM   #13 (permalink)
what kind of overload speings are you using. did it make the ride worse.
ktmstarr is offline   Reply With Quote
Old 04-12-2005, 09:40 PM   #14 (permalink)
It changed very little. If anything it made it better. Less bounce in the rear. Search: DRIVE TRAIN CLUNK for helper spring info.
Old 04-12-2005, 09:44 PM   #15 (permalink)
Search: DRIVE TRAIN CLUNK all of page 3
