Go Back   Nissan Titan Forum > Titan Discussion > Buy/Sell
Buy/Sell Got some parts or a truck you need to sell? Need to find something? This is the place to look.
If you are unable to find a used car here, you may try our Used Car search engine at the following URL: Used Car Search, or simply put your Zipcode into the following box and a direct search will be done in your area.
Old 04-25-2005, 10:41 AM   #1 (permalink)
Lightbulb New in box, Ultra Stargazers in 20x9 to fit Titan, chrome plated, $189 ea!!
I got a killer deal on these so thought I would pass it along! The local wheel warehouse is closing these Ultra Stargazer Type 140 in 20x9 out, so I picked them up at $189 ea + tax, I paid more than that for my 17x8 Ultra wheels 6 mos ago
I don't have mine mounted up yet, but man do they look sweet in the box . Huge chrome lip, deep dish style, look awesome. I'm not sure how many sets they have but I'd guess a few. They also have (2) other styles at this price - the Ultra Type 191 (curved, split 5 spoke) and the Type 20. They are only in stock (and on closeout) in OUR bolt pattern, 6 on 5.5". So if you want a set email me at Justins311 at hotmail.com
They are located in the Boise area, so if you can't pick up, figure in shipping as well (likely about $80 total most places). I travel back and forth to the Tri Cities Washington quite a bit so if you're real real nice to me, I could drop off a set there for you as well
Will post pics when I get them mounted up, going for some 305/55/20 Nittos as soon as I can afford them!
Justin311 is offline   Reply With Quote
Old 04-25-2005, 06:17 PM   #2 (permalink)
Wow.,..I figured people would be all over these. Guess I must have bad taste in wheels
Old 04-25-2005, 06:34 PM   #3 (permalink)
FdngFrnzy's Avatar
What is the offset and backspacing? Are they chrome or polished? They do look nice!
2004 Titan SE King Cab White 2wd
6" ProComp Suspension Lift w/ PRG's Fox Coilovers, MX6 rear shocks & Traction bars
3" PA Body Lift & PRG's Deaver Rear Leaf Spring Pack
37x13.50x20 Nitto Mud Grapplers 20x10 Helo Maxx6 chrome rims
Custom grill inserts by DUNDER23
OEM Bug Deflector & Class III trailer hitch
Hatchie Bottom Custom Fit CAMO seat covers-FRT/R
Retrax
Coming soon...
Custom dual exhaust w/ side exits, CAI, ???
It's a CANES thing...You wouldn't understand!
PICS in the gallery!
FdngFrnzy is offline   Reply With Quote
Old 04-26-2005, 01:28 PM   #4 (permalink)
Backspacing is just a term used to describe offset, but from the opposite view
The 20x9 is a +18mm offset. As stated in the title of the post ( ) they are chrome plated.
Let me know if you want a set and I'll hook you up!
Old 04-26-2005, 02:39 PM   #5 (permalink)
TOK
TOK's Avatar
I'm more into 17" wheels with offroad tires than the street stuff, but I still think those are really cool looking.
04 XE 4x4
1000 Pounds Of Crap In The Back Levelling Kit
TOK is offline   Reply With Quote
Old 04-26-2005, 02:44 PM   #6 (permalink)
FdngFrnzy's Avatar
Justin311:
Sorry about missing the "Chrome" part...
I am looking for a negative offset(-25), I am lifting the Titan and I want them to stick out past the fenders...Thanks anyway! Good luck selling!
Retrax
Coming soon...
Old 04-26-2005, 03:06 PM   #7 (permalink)
Justin311:
I noticed in your sig you are wanting 10" wide wheels. You do know that the offset is relative to the width of the wheel, correct? So you need to specify that you are looking for a (for example) 9" wide wheel with +18mm offset, or a 10" wheel with a -25mm offset.
A 0 offset means that the hub sits at the center line of the wheel, or on a 9" wheel, that would mean it sits at 4.5" in from the back, which equals 4.5" backspacing. (These numbers are not exact as there is some math involved in subtracing off for beads, etc.)
A 10" wheel with - 25mm offset means that a full 6" will be to the "outside" of the centerline (hub) and 4" will be inside. You will be applying significant stress to the axle and bearing with these wheels, and could have parts failing very quickly. Just be very sure of what you are getting into before blindly purchasing some wheels based on an offset
A neat calculator: http://toy4two.home.mindspring.com/offset.html
Old 04-26-2005, 07:14 PM   #8 (permalink)
goathead's Avatar
while those are great looking wheels, i really wonder what they will look like w/ a 6-lug pattern. sometimes, 5 spoke wheels w/ 6-lug patterns look "wierd". any pics?
steve
Old 04-26-2005, 09:01 PM   #9 (permalink)
I will have some once I mount them up, but none right now they're still all packaged.
Old 04-26-2005, 09:30 PM   #10 (permalink)
goathead's Avatar
cool....cant wait
steve
Old 04-27-2005, 04:28 AM   #11 (permalink)
hkusp45's Avatar
I wanna see them mounted!!
hkusp45 is offline   Reply With Quote
Old 04-27-2005, 05:13 AM   #12 (permalink)
What do the other two wheels look like?
Got a picture of them? I found these links but not sure which ones they are?
http://www.ultrawheel.com/wheel_brand.cfm?brand=1
http://www.superbuytires.com/wheels/brand/Ultra/
intrepid is offline   Reply With Quote
Old 04-27-2005, 08:30 AM   #13 (permalink)
Type 20:
Type 191:
Old 04-27-2005, 08:34 AM   #14 (permalink)
Also, I should mention almost every truck I've ever owned is a 6 lug (toyotas and nissans) and almost every wheel I've ever owned is a 5 spoke. Here is a very similar ultra wheel (in a 17x8) with identical center caps/lug nut pattern, in a 5 spoke (from my tacoma ): see next post
Old 04-27-2005, 08:40 AM   #15 (permalink)
