Just curious, what did you replace it with? Isn't removing all that pretty in-depth, or is that just the version with Navigation to? Sorry to get off topic a bit..
just curious, what did you replace it with? Isn't removing all that pretty in-depth, or is that just the version with navigation to? Sorry to get off topic a bit..
I replaced mine, its not bad. Just has like seven harnesses in back haha. You end up only using the climate control harness, air bag light, and radio, bluetooth etc....all plug and play. But steering wheel controls take a seperate $70 box that complicated as hell to hook up if you want to retain them. Really simple actually just be sure you get the correct radio cause theres a metal brace behind it and if the new ones to long it wont go in, I needed right angle rca adapters for sub output, ended up with 1/8" clearance in back.
