Buy/SellGot some parts or a truck you need to sell? Need to find something? This is the place to look.
If you are unable to find a used car here, you may try our Used Car search engine at the following URL: Used Car Search, or simply put your Zipcode into the following box and a direct search will be done in your area.
i just got saws so im selling my used 2.5" prg leveling spacers 2wd only. youll have to buy the bumpstops from greg, he sells them in a resale kit for around 20$ . when i removed them some of the the studs came off with nuts on them since i locktite the nuts on, so you either can just screw the studs in with the nuts or tighten the studs down with the spacer in a vice till the nuts break loose, very simple. soooo for price......$75 shipped anywhere in the USA. they cost 179$ new.
PRICE LOWERED!!!
let your old age be childlike, and your childhood like old age; that is, so that neither may your wisdom be with pride, nor your humility without wisdom.
if you're comfortable taking your upper control arms loose from the spindles and pulling the shocks you should be fine don't forget to get new pins to lock the A-arm back onto the spindle
is this something that can be self installed, I have tools and mechanical knowledge, im just new to suspension mods
yup, its all bolt on and fairly simple. goes on pretty quick too, youll just need a alignment afterwards.
My suggestion is to call Greg at PRG Products and order the leveling spacer hardware kit. It includes everything you'll need except the spacer block itself. As was said, it's around $20-25 and includes NEW bumpstops, NEW bolts and washers, and NEW cotter pins for your upper ball joint nut.
The tools you'll need are just some metric sockets (19mm, 17mm(?), 14mm), 1/2" & 3/8" drive ratchets, some 1/2" drive extensions, 19mm & 17mm wrenches, needlenose pliers, rubber mallot, jack, jackstands, drill (cordless is good), and beer. Mostly just basic tools.....
im back from mia, spacers still for sale 75$ shipped anywhere i have paypal or accept check/money order but wont ship till it clears.
no photo, i can take a pic later when i get home. i rethread locked the studs down so who ever buys them are set and just needs the hardware kit from greg. they are solid alluminum so they are tough and just have unavoidalbe minor scratches from install/uninstall. feel free to ask any questions. mahalo
