Go Back   Nissan Titan Forum > Titan Discussion > Buy/Sell
Buy/Sell Got some parts or a truck you need to sell? Need to find something? This is the place to look.
Old 04-10-2009, 03:01 PM   #1 (permalink)
travelship's Avatar
Audio Stuff F/S-JL Audio, Image Dynamics, Sundown
Used audio equipment for sale, very good condition.
JL Audio 500/5, includes RBC-1 bass remote-$300 shipped
Image Dynamics CXS64 Chameleon components. Includes masonite adapter baffle to mount the mids in front doors and custom mounts to put tweeter in stock dash location. You will need to slightly trim the underside of your stock tweeter covers with a razor blade, as shown in last photo. One of two plastic tabs that hold the clear crossover covers on are broken on both crossovers. They do not stay snapped on, I had them held in place by my amp rack. Cleansweep and CTX6 coaxials shown in first photo are not available for sale. $200 shipped.
Sundown Audio-- I have decided to keep the sub for now, I might need it for the motorhome. Sorry, I can't edit the thread title.
04 4X4 LE Crew Cab, Purchased Used 3-06, Sold 3-09
Gone, but not forgotten!
Without Trucks, America Stops
If you got it, a truck brought it.
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
travelship is offline   Reply With Quote
Old 04-10-2009, 04:12 PM   #2 (permalink)
travelship's Avatar
Re: Audio Stuff F/S-JL Audio, Image Dynamics, Sundown
IF you have an '04 and you want both items, I'll give you my amp rack overlay.
Old 04-10-2009, 04:19 PM   #3 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
You did a nice job on that install! Why are you taking it all out, time for a new truck?
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 04-10-2009, 04:26 PM   #4 (permalink)
travelship's Avatar
Sold the truck 2 weeks ago to lower my monthly expenses. Not a moment too soon, I was just laid off today. A little stressful losing health insurance with the baby due in 3 weeks, but we'll get through it. I am first back when they need someone.
Old 04-11-2009, 10:29 AM   #5 (permalink)
travelship's Avatar
Weekend bump, this is very nice equipment. The JL is a great all in one amp, and the IDs sound sweet.
Old 04-22-2009, 12:06 AM   #6 (permalink)
travelship's Avatar
I'm surprised there has been no interest in these. Price drop to $275 shipped for the amp, and $175 shipped for the component set.
Old 04-22-2009, 08:17 PM   #7 (permalink)
for the ID components...are you including the mounting baffles for the mids and highs??
krnnerdboy is offline   Reply With Quote
Old 04-22-2009, 08:18 PM   #8 (permalink)
nvm...I just actually read the posts...
Old 04-23-2009, 01:54 AM   #9 (permalink)
any ideas what the differences would be between your ids vs ctx65cs?
Old 04-23-2009, 02:28 AM   #10 (permalink)
travelship's Avatar
It looks like the CTX65CS are ID's budget component set. The Chameleons have a carbon fiber mid cone, and a 2 inch tweeter vs a 1 inch in the CTXs. The Chameleon crossovers also have a 3 position switch to adjust the tweeter output.
Old 04-23-2009, 02:36 AM   #11 (permalink)
travelship's Avatar
Info from the ID website:
For the CTXs:
The CTX speakers are the affordable solution for the autosound enthusiast seeking a high performance speaker system. With a rich well balanced sound and excellent tonal characteristics that highlight the incredible detail. CTX speakers are engineered to make efficient use of every watt allowing them to shine at any power level. A secondary benefit fo this high efficiency is that they are capable of very high output levels.
The CTX use materials most manufacturers reserve for use in their top of the line speakers. Silk dome tweeters with neodymium magnets, polypropylene mica filled cones that are stiff, yet light, and well-damped, nitrile butadiene rubber surrounds. The result is sound quality that is far beyond expectations and far beyond their price points.
CTX component coaxial speakers feature a long excursion mid-woofer design that handles high-power amplifiers effortlessly with low distortion allowing higher output levels. The Silk Dome CTX tweeters deliver the dynamics and detail of a metal dome tweeter without the listening fatigue normally associated with metal domes.
FEATURES:
CONE- Mica reinforced polypropylene material has good stiffness to weight ratio while being UV stable and water proof.
SURROUND- Nitrile Butadiene Rubber (NBR) surround provides long life and consistent compliance over a wide range of temperatures with good UV stabilility.
TWEETER: Coated silk dome neodymium magnet tweeter in 2 sizes 20mm & 25mm
TWEETER MOUNT- Swivels up to 18 deg for optimal off axis response
VOICE COIL- 2 layer high temperature copper voice coil wound on anodized aluminum former for high power handling and reduced thermal power compression
TERMINAL- Epoxy resin fiberglass terminal pads with heavy gauge plated terminal connections for long life in all weather conditions
For the CX Chameleons:
The Chameleon CXS component separates are an innovative speaker system. They allow you to choose the best mounting options for your vehicle.
The Chameleon Components provide dynamic transient response with superior resolution of details through the critical midrange and high frequencies. This high fidelity and dynamic range are a result of their high efficiency. This superior performance is immediately apparent with your first listen. The CXS component sets are available in 5.25" and 6.5" sizes with a choice of 2 ohm or 4 ohm versions.
What truly sets the Chameleon apart from other speakers besides their sound quality is the ability to choose between two mounting options. The midrange and tweeter can be mounted separately or the tweeter can be mounted on the CX midbass driver for a point source driver.
The NX30 tweeters provide a level of performance that is not usually attained from small neodymium tweeters. Their incredible performance reproduces the most complex musical passages with incredible clarity, dynamics, and detail without harshness or listening fatigue. Their very smooth frequency response, both on and off axis, allows them to excel in many different mounting locations.
The X2 and X4 passive crossovers bring together the performance of the NX30 and the CX mid-bass/midrange drivers. To properly match the output level of the NX30 they are equipped with a three position tweeter level switch. Air core, low DC resistance inductors and high stability metal film capacitors are utilized for low distortion and minimum insertion loss.
FEATURES:
Carbon Fiber cone- CX cones are multiple layer carbon fiber formed from two non-similar matrix materials, Very light weight and very ridged for maximizing clarity and detail.
Tweeter Mounting options- The eye ball flush mount allows you to optimize the output by directing the NX30 for better performance in both door or pillar locations, while the tweeter stand places the NX30 in the Coax mode for best overall performance.
Silk dome tweeter- The unique 30mm damped silk dome is free from resonances and break up modes that color the sound and exploiting the newest neodymium motor designs along with dome dampeners for better response.
Surround- Nitrile Butadiene Rubber (NBR) surround provides long life and consistent compliance over a wide range of temperatures with good UV stabilility.
Voice Coil- Edge wound aluminum ribbon wire voice coil design with black anodized aluminum former yields high power handling and maximum motor force through more efficient use of the magnets energy.
X-over- Air core, low DC resistance inductors and high stability metal film capacitors are used for low distortion with virtually no insertion loss. Matching the output level of the NX30 is easy using with a three position tweeter level switch.
Old 04-23-2009, 08:33 AM   #12 (permalink)
Banned
do you still have everything and do you have the amp rack too? LMK
SiMpLyMoDiFiEd is offline   Reply With Quote
Old 04-23-2009, 01:43 PM   #13 (permalink)
travelship's Avatar
Everything sold!!!
Old 04-23-2009, 02:12 PM   #14 (permalink)
Banned
Old 04-23-2009, 03:16 PM   #15 (permalink)
travelship's Avatar
Originally Posted by username80 View Post
That is definitely the grin you're going to have on your face when you get this stuff installed. I'm boxing them up right now, I should be able to get them on the FedEx truck today. I'll pm the tracking numbers soon.
WTT: Brand new Car audio Stuff for Titan Stuff project titan Buy/Sell 1 09-11-2008 02:02 PM
New sd1v2 sub from sundown audio tech12volt Titan Visual & Audio Discussion 26 10-24-2007 09:22 PM
Complete Custom Car Audio by P-Dizzle and Tech12volt ft. Sundown Audio (Pics) P-Dizzle Titan Visual & Audio Discussion 64 07-08-2007 08:24 AM
Sundown Audio Subwoofer! t22a80 Titan Visual & Audio Discussion 29 04-02-2007 10:12 AM
Sundown Audio Prototypes! P-Dizzle Titan Visual & Audio Discussion 9 03-24-2007 06:18 AM
