Go Back   Nissan Titan Forum > Regional Forums > Canada Forum
Old 10-03-2005, 12:57 PM   #31 (permalink)
Originally Posted by TitanHopeful
My permanent brake fix was done OK on Friday. Brake pedal is a bit firmer afterwards. I was somewhat surprised that the fix includes replacing rotors on the front only. The rear ones are turned if they appear OK. New pads on all four wheels though. This seems to be consistent with the TSB.
The rear brakes apparently are not doing much of the braking. When I changed the rotors at about 18,000 miles (judder, pedal going to the floor), the OEM rotors in the rear still looked like new, compared to the front rotors, which were showing substantial wear.
Old 10-09-2005, 05:23 PM   #32 (permalink)
I live In London Ont. Have had the brakes worked on 3 occasions. The first time the dealer machined the front rotors and replaced some of the caliper hardware. The fix lasted about 5000kms, the judder reappeared just as bad as the first time. I took it in the second time and they checked it over and told me that they were going to replace the rotors, but that they had to be recieved from Nissan. Unfortunately they didn't resurface the rotors to fix it temporarily, and I'll tell you why I wished they had. I had to wait 3months for these parts! Anyway the third fix replaced all rotors and pads front and rear. I hope this is the real fix this time. Iv'e only put about 800kms so far.
woodchopper is offline   Reply With Quote
Old 10-18-2005, 09:29 PM   #33 (permalink)
wildwood's Avatar
I've Got New Brakes....
The new brakes seem alright...finally.
I had the rotors turned once at about 16,000 and at about 25K there was a little shimmy reappearing...
But now all is well.
Wildwood
Calgary, AB
Red Titan LE CC 2004
wildwood is offline   Reply With Quote
