Go Back   Nissan Titan Forum > Titan Discussion > Detailing & Truck Care
Detailing & Truck Care Discuss detailing techniques and products for your truck here!
Old 11-15-2009, 06:53 PM   #1 (permalink)
Water spots on the hood
I have what look likes water spots on my hood. I contacted Meguiars and they sugested their Ultimate Compound. It didnt even touch the spots. Is there something else to use or is the hood damamged? Thanks in advanced!
BucFanTitan is offline   Reply With Quote
Old 11-15-2009, 07:48 PM   #2 (permalink)
USN HM 350Z's Avatar
Re: Water spots on the hood
white vinegar. Then wash the truck right after wards. Then clay bar and polish/seal/wax the truck.
2008.5 Nissan Titan -JBA exhaust piping with Bullet muffler, CST, Bilstein, 3inch PA Body Lift, Toyo AT's, PRG traction bars, CDT Audio, Sundown Audio, RE Audio, ipod (Thanks Tech12Volt).
2009 Subaru WRX - SPT Cat Back Exhaust, Cobb Access Port, SPT Heat Shield, SPT Front Strut Brace, Alpine W205 with full ipod control
USN HM 350Z is offline   Reply With Quote
Old 11-15-2009, 08:01 PM   #3 (permalink)
gweasel77's Avatar
I use their quick wax after i wash mine every time. Work's great! Water bead's right off!
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
Custom 4" Ram Air / Fujita Intake w/ DEI Heat Shielded Box / AirRaid TBS / TB Screen Removed / TB Coolant Bypass / '08 Intake Manifold / Trans. Cooler / Nismo LT Header's / Banks Monster Exhaust / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding System / Burn-Out Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior:
Ruff Racing R286 22"x9.5" Chrome's w/ 305/45/R22 Nexen Roadian HP's / Stillen Diff. Cover / ST 2" Drop Shackles / Traction Springs / DDM 8K HID's / Armada Air Dam / SolarGard Tint / Tow Hook's / Debadged
13.91 @ 96.82MPH
gweasel77 is offline   Reply With Quote
Old 11-16-2009, 06:55 AM   #4 (permalink)
Do you mix the vinegar or just pour it on? Should I wet the truck first or pour it on dry?
Old 11-16-2009, 07:55 AM   #5 (permalink)
Bama334's Avatar
Here's the 411 on water spots and prevention. Water spots are made when the water(from your hose) dries on your hood and leaves calcuim depoists. Keep it wet until your finish, towel dry and no water spots. And no clay bar, waxes etc.
2004 Titan LE CC 4X4 Offroad Blizzard
PRG Performance Package
PRG Rear Shackles- PRG Sway Bar End links
True Trac
315 BFG's on factory 17" OR Wheels
Bama334 is offline   Reply With Quote
Old 11-16-2009, 08:37 AM   #6 (permalink)
Yeah I know thats true Bama334. But the ones I have on their now I need to get off the paint.
Old 11-16-2009, 09:26 AM   #7 (permalink)
20TexasTitan08's Avatar
mine is black and i have had the same problem, wax wont get it completely out. especially when u look at the hood at an angle. it even seems like the hood is just harder to wax off than the rest of the truck. Sorry man i hope someone gets u a good solution. i have tried viniger and it works but not completely.
08, Galaxy Black, CC, LE, Tow package, Charcoal leather, OEM tube side steps, and OEM fog lights
Interior Mods: Floor mats, all weather floor mats, Cobra 6 band radar detecter
Exterior Mods: Bug sheild, mud flaps, 35" Nitto Mud Grapplers, 20" Moto Metal 951's
Suspension Mods: 4" CST spindles, Sway-A-Way coil overs, leaf spring pack, blocks, pro-comp shocks
Audio Mods: Tech12Volts custom enclosure; Rockford Fosgate Capacitor; 4 Rockford Fosgate P2 10" subs pushed by a Sun Down 1500D amp; 4 Clarion quality series component 6 1/2" speakers and 4 Kenwood KFC - T207 tweeters pushed by a Kenwood KAC - 8404 amp! Hands down the best system I have ever heard
Wish list(in order): Injen or Volant CAI, Uprev , Train Horn, Tru Trac, and...Stillen S/C
20TexasTitan08 is offline   Reply With Quote
Old 11-16-2009, 12:23 PM   #8 (permalink)
I have the sme problem, well should I say I had the same problem with my 09 Black Titan Crew Cab, but mine were on the roof not the hood. So I asked this forum and someone on here suggested Meguiar's Cleaner Wax. It worked great, but it takes alot and I mean alot of elbow grease. I put it on and took it off by hand, I don't know if you can use a buffer or not but I am not that great with one so I would cause more damage than good. I know it took 1 hour alone for the roof. I think it took around 5 hours for the whole truck.
Hope this helps.
hawgfan is offline   Reply With Quote
The Following User Says Thank You to hawgfan For This Useful Post:
BucFanTitan (11-16-2009)
Old 11-16-2009, 04:20 PM   #9 (permalink)
50/50 mix of the vinegar and water
The Following User Says Thank You to USN HM 350Z For This Useful Post:
Old 11-16-2009, 04:26 PM   #10 (permalink)
Colten K's Avatar
ya i use quick wax afer i wash my black T every time, our water at home has a lot of calcium in it and it leaves a lot of white water spots. the car washes in town leave them as well but not as bad, just use quick wax or Eagle one wax as you dry i think it's called.
2005 SE 4X4 KC BT Galaxy Black
Billet Grill
34" NItto Graps
Air Aid CAI
Exhaust Tip
Mini Lift with 09 Pro 4x CO's
5% Tint
LED interior lights
Back Flip box cover
Bed lined skid plate/mud flaps
Chrome bug deflector
More to come!
Colten K is online now   Reply With Quote
Old 11-16-2009, 04:30 PM   #11 (permalink)
I have some of the cleaner wax I will give that a try. Thanks.
Water Spots Slight515 Detailing & Truck Care 53 09-14-2008 03:03 PM
water spots on rims? gabriel c. Titan General Discussion 5 10-28-2007 11:44 AM
Water Spots bigwilltitan Titan General Discussion 11 02-05-2007 08:34 PM
water spots............. niceun Titan General Discussion 16 06-27-2005 10:39 AM
