When the time comes I'll just put in a call to the local mobile zaino detailer.
How do you afford that being such a lazyass?
Skyboi, my california car duster says it won't scratch the paint, and it hasn't as far as I can tell. I bought it because my truck gets a layer of dust on it after a day because the area I have to park in at work is dirt. I dust it the first few days after I wash it to enjoy a clean vehicle at least for a few days. Is this not a good idea? Will it damage the paint over time? I wax my vehicles every 6 months, so should I wax more often if I dust it frequently?
__________________ '08 Titan SE, Crew Cab, 4wd, LWB, Smoke
Bullwinkle...Great question here.
My take is this...Anytime you touch the paint whether with your finger, wrag, duster whatever, you're going to leave a microscopic scratch in the clearcoat. Now, repeated touches will compound those little scratches and over time you will dull the clear coat. Since the Clearcoat is like a lens to the color, when it is scratched and cloudy, the vehicle looks dull. Then the only fix is buffing. This will take a long time but will eventually happen.
My advice: If the dust really bothers you and you feel like you have to wipe it off, Try these tips.
1. Try compressed air if you have it...works great and is gentle
2. Flow some water over it from a hose with no nozzle but do dry it (unless you hand wash it)
3. Very lightly use your duster and keep it clean. Don't listen to the myth that "the dirtier it gets, the better it works" the dirtier means more coarse abrasives you're wiping with
4. Wax it more often to give yourself a microscopic layer of wax to ride on.
One word on buffing... RUN from anyone that promises "swirl free". Can't be done.
Anytime you run a machine on your paint, you will have machine marks..PERIOD
A person that is expert in buffing(uhhum) can minimize and pull the track marks out so there are less of them. But you will have a wave in the paint forever. Waxing often fills in the swirl marks and little imperfections...When the wax dries out and decays from the elements the swirl becomes visible again. Waxing often greatly helps your paint.
Hope this helps...Good luck!
__________________ '07 Granite SE CC 4X4 Pop Pkg * Tow Pkg Fogs Utilitrack * Bed Extender * Bed Divider * Spray-in Bedliner LUND Interceptor Stainless Steel Bug Guard SYLVANIA Silverstar ULTRA 9005/9006 EXTANG Trifecta Signature Series Trifold Tonneau TAURUS 4510 5 shot "The Judge" Revolver
Paying a professional for professional results is just fine by me. I have no experience with a buffer/polisher and zaino isn't cheap so I'll leave that task to the pros.
2008 Crew Cab 15.33@91mph busted
New Best 15.05 at 92.93mph!
283hp and 331lb ft busted
301hp and 353lb ft!
New track times coming this month
I used to fix botched buff jobs all the time...They can get pretty ugly. For some reason, some people think that an abrasive pad spinning at 2500 rpms is a piece of cake.....
There are some good ideas floating around here. If I may add some..
When I wash I use a gentle spray nozzle and wand it flow a large amount of water gently and that want make reaching the top and underneath parts much, much easier.
I use a 3 bucket wash 1- 2.5 gallon and 2 - 5 gallon.
2.5 gallon for wheels and inner fender wells.
2- 5 gallon, one with the suds and one clean water for rinsing out the sponge.
Micro-fiber all the way..
leaf blower for drying..
For the tire finish a product called Onyx you can get at napa.
Mothers pre-cleaner.
P21s wax for the finish. (the BEST wax I have ever used)
Stoner products for the glass and such.
10 hours later "a labor of love" A beautiful truck.
My experience, clay bar is not for the novice user. you can really screw up a vehicle with one if you don't know what your doing.
Colonite is a good "insulator wax" extremely hard to get off, liked the results but it did not last long, less than a month.
Have a buffer, Milwaukee matter of fact, have all the compounds by 3m, pads and such. unless you have totally neglected your truck or had some unfortunate event happen. You don't need it. If you do, leave it to the pro's.
I almost forgot, I also use a filter on the garden hose when I wash, It's a whole house filter set-up with the charcoal filter. I only use these when I wash the vehicle's and not for the plants...
Water softeners are great for relaxing waterbeading...really helps eliminate hard water spots and chemical deposits on paint....
I do the same... At the end of the final wash, I take the nozzle off and "float "water over the top with a "sheeting" agent to have the water quickly run off.
Personally, I've never used it, but I know a lot of guys with very expensive cars that do.... In my other club.... They swear by it, and yes, it gives beautiful results.
I also like the P21S carnuba wax and if I was going to use a carnuba wax, they would be one at the top of the list and there is also a good carnuba wax sold in Harley shops that is supposed to be the same wax under a different name, maybe S1000 or something. I used it with the same results during my carnuba phase and it is about half what the P21S costs.
I use nothing but microfiber and polymer protectant now and the carnuba can be layered on top if you like but nothing beats the convenience of Klasse that is applied with a damp applicator and wiped right off. If you still have a little water around when you apply it, no problem, very easy to use with good results.
I also like to polish the truck with the Menzerna products and a RO buffer, gentle, safe, effective for minor problems like swirl marks the "professional" left behind. Nobody cares about your vehicle like you do and would charge an arm and a leg to work on the thing for a day or two, they gotta eat too.
If you really want to know how to DIY, call up Properautocare.com and ask those folks. They carry most of the finest products and are very helpful. Good luck and happy detailing.
__________________ IRC VK56 Member "BIG CHIEF WANNARACEUM"
2005 XE, "Land Shark",1/4 MILE: 13.851 AT 98.52 Full Street Trim on Snow Tires Record HolderBuild date 3/05
Performance mods: UpRev Osiris, JWT cams, NISMO CAI, NISMO True Duals and NISMO Headers with Swain's White Lightning Coating, Suncoast Ram Air Hood, Tru Trac, Burnout mod
Stereo mods: Pioneer Premier DEH-P880PRS head unit, Audison LRX 4/300 Amp, Boston 6x9 coaxials front & Focal 6.5 coaxial rears with JL tweeters in dash.
The reason I ask is that I know many people that say this or that is the best only to find out that they've never tried anything else.
If you can convince me that it's really good I'll order some.
It is the best THAT I HAVE USE SO FAR. Did not say it is the best.
Criteria...Ease of use, end results, durability.
The reason I ask people to try this is because of the results that I have got using this product. I just trying to give your advice of trying a different product. How would they know if they never tried it?
Cool...Hey let me ask you the ultimate criteria question to seal the deal
If I were to put a coat on and say a 90 degree day in full sun, and I accidentally thought I heard something fall over in the fridge....So I open it up and see some beer in there. In order to be sure that the beer has has not been tampered with I test a few and then realize that I still have wax on the Titan.
