Go Back   Nissan Titan Forum > Titan Discussion > Detailing & Truck Care
Detailing & Truck Care Discuss detailing techniques and products for your truck here!
Old 03-13-2008, 07:14 PM   #1 (permalink)
engine cleaning
what is the safest way to clean my engine
huntingtonbh1 is offline   Reply With Quote
Old 03-13-2008, 07:36 PM   #2 (permalink)
Buildwonder's Avatar
Re: engine cleaning
Here's what I do:
-Spray a good degreaser (Exits, Simple Green, Greased Lightning, etc.) over entire dry and COOL engine.
-If engine is real dirty, get a small brush and scrub the bad areas.
-Rinse with garden hose-------NO PRESSURE WASHERS!!!
-If needed, soak with degreaser again and let it sit for 5 minutes or so. Rinse again.
-Be careful with the degreaser as overspray on your fenders will eat the wax away and you'll have to re-wax. Keep the fenders wet and rinse thoroughly.
Do this every time you wash your truck and your engine will stay clean. If you do it often enough, you can just soak it with degreaser and rinse without brushing. I then dry everything with an old bath towel. Don't use your good chamois or microfiber towels for this as you may pick up some grease or grit or something.
2005 SE Crew Cab 4x4
High Utility Bed Package with Bed Divider and Bed Extender
Popular Package w/Buckets and Rockford Fosgate
No real mods yet except for Truxedo Lo Pro
"It is what it is!"
Favorite Quote: "IF YOU DON LIKE CAPITALS LETTERS TO BAD DONT READ IT YOUR ARE THE LOSER NOT ME" --verbatim; from RAPINEDA61
GrammarWhore™
Buildwonder is offline   Reply With Quote
Old 03-13-2008, 07:39 PM   #3 (permalink)
Carbeaux's Avatar
Re: engine cleaning
Simple Green (mentioned above) is great for this.
Hook 'Em Horns!
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand that...
Carbeaux is online now   Reply With Quote
Old 03-13-2008, 07:50 PM   #4 (permalink)
Arachnid's Avatar
Re: engine cleaning
The safest way is to use old rags and towels and a light cleaner like Simple Green. Spray and wipe, don't use any water.
AKA: Critter Whore™
Arachnid is offline   Reply With Quote
Old 03-13-2008, 08:06 PM   #5 (permalink)
Re: engine cleaning
I use water because Pennsylvania is apparently responsible for 1/3 of the world's annual salt usage for the roads in the winter. I like to rinse every nook and cranny with good, clean water to prevent as much corrosion as possible. Salt is nasty sh*t, as I'm sure you all know!
"It is what it is!"
GrammarWhore™
Old 03-13-2008, 08:17 PM   #6 (permalink)
Re: engine cleaning
thanks for your help
Old 03-13-2008, 08:58 PM   #7 (permalink)
Skyboi's Avatar
Re: engine cleaning
Great writeup Buildwonder. Right on the money.
2 words of wisdom:
1. Leafblowers work great for getting water out of hiding places.
2. Be careful using dressings on hoses. They collect dust and dirt. That dust works like sandpaper on the underside of corrugated hoses and eventually wears holes in the creases. I've seen it many times.
Clean and dry work best here.
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Old 03-14-2008, 12:50 PM   #8 (permalink)
FourDoor's Avatar
Re: engine cleaning
One more tip...
Cover up the visible electrical connections. I've seen it time and again with people trying to wash their engines down before only to find electrical problems later since water seeped into the connections and corroded the connections.
FourDoor is offline   Reply With Quote
Old 03-14-2008, 12:56 PM   #9 (permalink)
bbomar's Avatar
Re: engine cleaning
Originally Posted by FourDoor
One more tip...
Also for those with an exposed CAI, cover it...
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Old 03-14-2008, 01:06 PM   #10 (permalink)
Nissan Mike's Avatar
Re: engine cleaning
Trash bag tied over the CAI filter and stick with Simple Green to prevent discoloring and streaking of paint and aluminum parts
Old 03-14-2008, 01:34 PM   #11 (permalink)
Re: engine cleaning
If you want it really clean, follow up the cleaning by using a vinyl dressing on all the plastic covers and rubber hoses. This makes it much easier to keep those parts clean in the future and makes everything look brand new. This is more something I do on cars however, since I get my titan dirty in the woods almost every week.
black sunshine is offline   Reply With Quote
Old 03-14-2008, 03:28 PM   #12 (permalink)
Skyboi's Avatar
Re: engine cleaning
Please see my quote from above regarding dressings on hoses...Trust me, I know from experience.
Pop Pkg * Tow Pkg
Fogs
Old 03-14-2008, 05:37 PM   #13 (permalink)
yamatitan's Avatar
Re: engine cleaning
I just hose mine out every time i wash my truck unless i have mud in the compartment. It stays really clean like this.
Procomp 6" ($1300.00)
35x12.5x18 Toyo MT's $1100.00)
PRG Offroad Traction Bars ($489.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
SAW coilovers ($1000.00)
Bushwacker Pocket style flares ($600.00)
Rear Sway-away piggybacks ($399)
Money wasted so far=$9073.00
Old 03-14-2008, 06:06 PM   #14 (permalink)
Carbeaux's Avatar
Re: engine cleaning
I don't dress the underhood plastic with anything. Like has been said above, it's just a dirt magnet. Just simple green, soak, and rinse.
Hook 'Em Horns!
Old 03-14-2008, 06:24 PM   #15 (permalink)
Re: engine cleaning
all the above, and when finished i always start it up right away and let in warm up and dry that way. I never let it sit to dry.
silver 2004 4x4, CC, LE (non big tow)
bought new in Feb '05
LazerLite tonneau
brake fix done at 22k, no issues since
nicest and most practical vehicle i have ever owned!
kman is offline   Reply With Quote
Cleaning the engine.. dj_empyre Titan General Discussion 24 09-10-2007 09:11 AM
Engine Cleaning 101 TexasTitan05 Titan General Discussion 12 07-13-2006 05:51 AM
Cleaning Engine regwood79 Titan General Discussion 21 02-04-2006 10:57 PM
Engine cleaning Bayou Titan Off-Topic Discussion 0 07-02-2004 08:27 PM
Engine Cleaning? Big Platinum Titan General Discussion 14 06-26-2004 12:34 AM
