Go Back   Nissan Titan Forum > Titan Discussion > Detailing & Truck Care
Detailing & Truck Care Discuss detailing techniques and products for your truck here!
Old 03-31-2008, 08:13 AM   #16 (permalink)
Yellomantis's Avatar
Re: Water Spots
Originally Posted by Skyboi
I like the craftsman cause I get double duty for my $$$. For $130.00 i get a helluva vac and over 200mph of wind with no exhaust or fuels to screw up my paint. I replaced the power cord with a 50 foot heavy duty one.
Can't beat it for drying though...Wet towels are a thing of the past...No touch drying is the way to go.
I may look into picking up that craftsman vac/blower combo! I sure hope they still sell it...
www.myspace.com/yellomantis
Old 03-31-2008, 11:01 AM   #17 (permalink)
Skyboi's Avatar
Re: Water Spots
Here it is Mantis... http://www.sears.com/shc/s/p_10153_1...&sbv=Craftsman
Detachable top is used as a blower
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Old 04-08-2008, 09:16 PM   #18 (permalink)
LittleRam's Avatar
Re: Water Spots
Hey Mantis...
I use my craftsman shopvac with detachable leafblower.. But really any one will do.
Clearcoat is like a lens that shows the crisp picture of the paint underneath. Think about it. The more you touch it, the more you micro scratch it.
The less you touch the clearcoat surface of your paint...the less you cloud it.
I wash my Titan, plug in my leafblower and grab a beer and dry....When dry...I wax, grab a beer and look at it.
All very easy and refreshment to boot!!
LittleRam is offline   Reply With Quote
Old 04-08-2008, 09:19 PM   #19 (permalink)
LittleRam's Avatar
Re: Water Spots
Check your PM I sent you a technique for the window spots...Good luck and let me know
Would love to know what you do to remove water spots from the windows!!
Old 04-08-2008, 09:33 PM   #20 (permalink)
Fishtracker's Avatar
Re: Water Spots
x2
I've got the same problemo.
08 Pro 4x+
When I die I hope my wife doesn't sell my mods or fishing gear for what I told her I paid for them........
Fishtracker is offline   Reply With Quote
Old 04-08-2008, 09:45 PM   #21 (permalink)
Buildwonder's Avatar
Re: Water Spots
Here I come to save the day! Use a clay bar and the spots should disappear.
2005 SE Crew Cab 4x4
High Utility Bed Package with Bed Divider and Bed Extender
Popular Package w/Buckets and Rockford Fosgate
No real mods yet except for Truxedo Lo Pro
"It is what it is!"
Favorite Quote: "IF YOU DON LIKE CAPITALS LETTERS TO BAD DONT READ IT YOUR ARE THE LOSER NOT ME" --verbatim; from RAPINEDA61
GrammarWhore™
Buildwonder is offline   Reply With Quote
Old 04-08-2008, 10:39 PM   #22 (permalink)
Slight515's Avatar
Re: Water Spots
I tried glass scrub by glass science and it seemed to have worked the best so far. It hasnt removed the water spots completely but it has removed about 70% of them. Next I think I am going to try a clay bar. If that doesnt work I will go with skyboi's tips which were very helpful.
Slight515 is offline   Reply With Quote
Old 04-08-2008, 11:10 PM   #23 (permalink)
sudden urge's Avatar
Re: Water Spots
50/50 mix white vinegar and water.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune +2 timing. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 04-09-2008, 08:18 AM   #24 (permalink)
Skyboi's Avatar
Re: Water Spots
Yeah guys, always start with the least aggressive method first. This way you won't run into as much trouble.
Here's the direction I'd go to get things off glass:
1. regular glass cleaner with a good scrubbing
2. Vinegar water mixture
3. Clay bar with a soapy water mix
4. 0000 steel wool (called 4 aught)
5. razor blade
6. Buff with a wool pad and light glaze.
Also...Get your wiper blades out of the way...Some cleaners will deteriorate the rubber and you won't realize they're screwed til you need them.
Hope this helps.
Pop Pkg * Tow Pkg
Fogs
Old 04-14-2008, 09:40 AM   #25 (permalink)
Re: Water Spots
I've read elsewhere that if a clay bar doesn't get the water spots out, then use a paint polish & buffer.
'08 Titan SE, Crew Cab, 4wd, LWB, Smoke
Bullwinkle is offline   Reply With Quote
Old 04-14-2008, 10:22 AM   #26 (permalink)
Skyboi's Avatar
Re: Water Spots
See above post... ^^^^^^ Last step!
Pop Pkg * Tow Pkg
Fogs
Old 04-16-2008, 11:23 AM   #27 (permalink)
Re: Water Spots
My point was polish would be safer than using steel wool or a razor blade, but I didn't want to come right out & say it because I appreciate the info you post & didn't want to offend you.
Old 04-16-2008, 11:57 AM   #28 (permalink)
Skyboi's Avatar
Re: Water Spots
NAh! no offense taken Bullwinkle...this is mild mannered Skyboi...I'm here to enjoy.
I know that people hear steel wool and think "sandpaper, scratch, abrasive etc..." But the 4aught or 0000 is very mild and I've found that if the claybar won't take something off...the 0000 or the blade will. just don't use a ton of pressure
The trick with the blade is to get the angle almost parallel at the glass not so much close to 90 degree but like 10 degrees.
Wool works great on bug guts, sap and fly crap
Pop Pkg * Tow Pkg
Fogs
Old 04-29-2008, 08:53 AM   #29 (permalink)
Re: Water Spots
Has anybody tried Barkeepers Friend for water spots on windows?
We have a black glass cooktop in our kitchen that was a complete pain to clean (the exact opposite of what I thought it would be) and somebody recommended Barkeepers Friend. Works like a charm, no hazing; the only drawback is it is a powder, like Comet, so after you polish the glass you may have to clean up excess product.
I have no idea about using it on paint. It seems it would be way too harsh.
Barkeepers Friend is available at Lowe's.
timeoff2fish is offline   Reply With Quote
Old 04-29-2008, 09:16 AM   #30 (permalink)
Skyboi's Avatar
Re: Water Spots
WOOOAAAHHH! Barkeepers friend is like COMET....Be careful here.
Go back a few posts where I explain going from mild to aggressive methods. Don't forget that Safety Glass is glass infused with plastic and can be scratched or etched if harshly cleaned. Start mild with non abrasive methods then move up to gravel. LOL!
Pop Pkg * Tow Pkg
Fogs
water spots on rims? gabriel c. Titan General Discussion 5 10-28-2007 12:44 PM
What takes hard-water spots off? Psychlone Titan General Discussion 29 07-10-2007 10:36 PM
Water Spots bigwilltitan Titan General Discussion 11 02-05-2007 09:34 PM
New Paint: When to wax, how to get "water spots" out CFDE2 Titan General Discussion 13 02-17-2006 12:09 AM
water spots............. niceun Titan General Discussion 16 06-27-2005 11:39 AM
