Go Back   Nissan Titan Forum > Titan Discussion > Detailing & Truck Care
Detailing & Truck Care Discuss detailing techniques and products for your truck here!
Old 03-30-2008, 08:57 PM   #1 (permalink)
Skyboi's Avatar
Detailing Advice-PM Me
Hey guys ... I know sometimes we all want to look smart on the boards but in real life I made a ton of money from guys that "tried it first themselves"... It's no big deal.
I owned my own business and detailed 5 cars a day inside and out for 5 years.
I started with fleet rental cars..The best learning grounds cause I buffed them like I rented them. Mistakes didn't matter so I took the chances and learned without remorse what can happen with chemicals and machines.
Once I completed my "boot camp" I developed quite a high end clientelle in my area... Ferrari. Mercedes coupes, Landrovers, BMW's......Did em all
I've blown the fresh paint off hoods with pressure washers and learned how much pressure to apply before disaster
I've experimented with various buffing speeds and pads and learned how to avoid disaster
I've burnt mags and headers and glass by using the wrong chemicals.
I guess what I'm trying to say is that I've already done what alot of you are about to do.
So.... If any one wants to PM me for quick advice instead of going on the public view...No problem, I'm happy to help. Either hit the public boards to help other members or PM me and I"ll try to help best I can.
Thanks Titan brothers
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Old 03-30-2008, 10:34 PM   #2 (permalink)
Yellomantis's Avatar
Re: Detailing Advice-PM Me
Nice to know man! I'll probably be hitting you up a few times soon. I'm trying to fix the "keyed" scratch on my Armada without going to a body shop. I just want to reduce it to the point of not really noticing it is there...
www.myspace.com/yellomantis
Old 03-31-2008, 06:21 AM   #3 (permalink)
Skyboi's Avatar
Take a good picture close up and send it too me...I'll give you a diagnosis.
I need to see the edges of the scratch clearly.
Pop Pkg * Tow Pkg
Fogs
Old 03-31-2008, 07:56 AM   #4 (permalink)
Supporting Vendor
P's Titan's Avatar
some of it is real nasty and it's from front to back.
my mods list
USE DISCOUNT CODE FOLGER FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 03-31-2008, 08:08 AM   #5 (permalink)
It's deep enough to get your finger nail in, but it doesn't look like it completely broke through the clear coat.
Old 03-31-2008, 11:10 AM   #6 (permalink)
Skyboi's Avatar
Take a look at this... http://www.langka.com/photos.php
It's a way to minimize the scratch... I've used my own version of this technique and it really helps.
Good luck..
Pop Pkg * Tow Pkg
Fogs
Old 04-22-2008, 09:54 PM   #7 (permalink)
Nissan Mike's Avatar
I'd like to polish the plastic headlight lenses on my 01 Pathfinder.
Can I use my Porter Cable 7424 on this? If so on high or low speed?
What product would you recommend?
Old 04-22-2008, 11:49 PM   #8 (permalink)
titaninak's Avatar
I need to do my headlight lens on my titan, i would love some pro advice too.... Thnks in advance bro
2006 LE, CC, BT, 4x4-Blizzard White
JBA catback, K&N cai, poweraid TBS, grounding kit, 2 degree timing, UpRev tuned, TruTrac
Debadged,4 piece billet grille, 20"Akuza wheels, tech12's w/ Memphis PR1-1000 amp / M-10's, Kenwood 7019 DD,DVD HU, Line of Fire LED light bar, LED third brake light, smoked tails, EFX HID lows and fogs, painted to match MADA air dam / inchannel window visors, Stillen Billet aluminum cap covers, 15% front tint, Non BT mirror swap. Truxedo lo pro tonneau cover
titaninak is offline   Reply With Quote
Old 04-23-2008, 05:13 AM   #9 (permalink)
Skyboi's Avatar
PM'd you with instructions....Let me know how you make out
Pop Pkg * Tow Pkg
Fogs
Old 04-23-2008, 05:23 AM   #10 (permalink)
Skyboi's Avatar
Hey Mike... Although I prefer a variable speed for this particular job, you can use the random orbit.
First thing to keep in mind is that most of the lenses these days are made of plastic....You know what that means....Be gentle and don't ride the machine in one spot.
Apply a light amount of a light glaze with an applicator and hit it once....wipe it down and check the progress. Should only take you 2 minutes per side and 5 clean up.
Trick...Apply the small amount of glaze more towards the center of the lense to keep the machine from pushing it into the gap between the paint and the lense...Makes for better end result.
Also, if the Random just isn't getting it done well enough for you, stop at a local detailer and ask if $10.00 would get a quick shot with a variable on the lense with a foam pad. Just talk like you know what your doing...would only take the guy 2 minutes tops.
Good luck and let me know how you made out....
Pop Pkg * Tow Pkg
Fogs
Old 04-23-2008, 06:06 AM   #11 (permalink)
roy365's Avatar
This is funny, I too wanted to know the secret to getting that glazed look off of any clear plastic lens. PM me too please!!!!
0-60MPH@5.60 & 1/4 mile@14.25 F/S/T
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 04-23-2008, 07:01 AM   #12 (permalink)
Thanks Skyboi,I'll give it a try
Old 04-23-2008, 07:16 AM   #13 (permalink)
Quartz's Avatar
Headlight glazing seems to be a popular topic. Maybe you could include your instructions in this thread. My wife's Honda has the same problem. We tried polishing compound and it helped some but there is still some glazing.
TT needs a detailing forum.
Quartz is online now   Reply With Quote
Old 04-23-2008, 07:44 AM   #14 (permalink)
Skyboi's Avatar
You're joking right Quartz?
Pop Pkg * Tow Pkg
Fogs
Old 04-23-2008, 07:52 AM   #15 (permalink)
Supporting Vendor
P's Titan's Avatar
I think you bought the detail kit? If you did use the clay bar, Swirl&Haze, and Revive Polsih. If you didnt get it, there is someone you know very well that has all of those!
my mods list
CrankyWhore™
TequilaWhore™
Detailing opinions... dank78 Titan General Discussion 5 09-27-2007 03:40 PM
Detailing USAFs13 Titan General Discussion 18 06-16-2007 01:07 PM
How much $$$ for Detailing? ptvolly Titan General Discussion 4 03-19-2007 11:53 PM
Auto Detailing Silvertitan7 Off-Topic Discussion 21 02-22-2007 10:00 PM
Details on Detailing buzzkillwill Titan General Discussion
