No problem...
There are a couple ways to go here with existing rust and rust prevention so here we go...
If you have existing rust you can do one of the following:
Method 1.
1. Clean the area from all debris, dirt, mud, etc...
2. asess the situation as to how bad the rust has moved through the area.
3. Break out the wire brush, sandpaper, file, grinder etc... and have at it... You must be sure to get it all down to "clean metal"
4. Clean again to prep surface for rubberized coating.
5. Tape and paper off area to prevent overspray
6. spray with light even coats letting dry between coats until it is sufficiently sealed to your satisfaction.
Method 2.
There are a few "rust converters" in the market that will change the makeup of rust back into an inert metal. I have used these in manufacturing plants when I used to work for a chemical manufacturer. They work great.
http://www.theruststore.com/Rust-Con...on-P40C10.aspx
Basically....Clean and dry the area...tape and paper off...Apply, and wait 24 hours.. Cures to a black finish and the rust is converted.
Important note though... This is not a "Pre" rust product... Only works on existing rust.
Now, onto "no rust" solutions
1. The rubberized undercoating in the cans will work alright but they won't last as long as a professional application.
Same basic principles apply.... Gonna need a few cans though to do it right.
1.Clean and dry the area,
2.Tape and paper it off to prevent overspray.
3. Work from the topside of what you want coated, then the sides farthest to you and then the bottoms. Remember that the standing water will most likely sit on the top and be held in corners where dirt and mug cling.
2. Using a water displacer alone won't cut it ...It needs to have a wax built in that will spread from using the water displacer as a cutting agent and allowing the wax to flow and the wax will "set up" and form a barrier against rust....This will need to be done every few months.
Clean up any overspray with either a good tar remover or Kerosene mixed with a little carwash soap.
Hope I was able to help you... Good luck and give me some feedback on your results so we can help the next guy...
