i guess I drove thru a a few construction zones and now I have tar all over the side of my Titan...what is the best product to remove this stuff without ruining my paint job. Targone by Turtlewax..sucks...helps please I can not enjoy my driving experience until I am riding clean again. Thanks in advance.
Goo off-wash it afterwards...
I used a bug and tar remover from Wal-Mart when it was fresh. But if it is like mine (been on my truck for months), I need to use a clay bar to remove it.
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
To be honest... One of the best and safest tar removers is KEROSENE. or GAS.
Gas drys too fast....
Fill up a spray bottle with some and add 1/2 oz of carwash soap to keep it from drying out...
After you've washed your truck of course....Mist the whole truck down and wait a minute....This will allow the tar to slightly run (so you can see where it is).
Next, go section by section with a soft nonabrasive bug/tar sponge.
If you can, let the product do the work...Don't be too eager to scrub it off...Let the stuff work for you. Work your way over the truck.
When done, Give it a final wash and hit it with a clay bar to get off any fallout and you're ready for wax.
There are some "citrus based areosol degreasers" that work really well also, but if you have a lot of tar you'll go through several cans. @ $6.99 a can...Kero or gas is cheap
Good luck and let us know how you made out so we can help other members.
__________________ '07 Granite SE CC 4X4 Pop Pkg * Tow Pkg Fogs Utilitrack * Bed Extender * Bed Divider * Spray-in Bedliner LUND Interceptor Stainless Steel Bug Guard SYLVANIA Silverstar ULTRA 9005/9006 EXTANG Trifecta Signature Series Trifold Tonneau TAURUS 4510 5 shot "The Judge" Revolver
Just thinking that hitting a truck with kerosene or gas and then having something ignite the fumes = flambe Titan!
WD-40 will strip down your clear coat and paint.
I wouldn't do it. i would follow the gas + soap method.
I didn't know that about WD-40. I used to use the Wal Mart bug and tar remover. If I remember right, the ingredients for that were the same as WD-40, so I switched. I usually re-wax after cleaning the tar off. Does anyone know why gas or kerosine is safer? WD is mainly toluene if I remember right.
Experiment all you want..... But if you want an inexpensive tried and true way to easily remove the tar from your vehicle without excessive harsh scrubbing, Take a quart bottle of Kerosene and mix a half ounce of carwash soap in it and go.
If you want to loosen all the things that have an adhesive base to it like say..... Your trim mouldings, mudflaps, pinstripes, emblems...I could go on...
Then I say go ahead and experiment
I'll run a thread on how to re-apply those things
Proper tool for the job!
'00 Camry LE - commuter car
Mods: Two dirty hubcaps
'06 Smoke XE CC FFV
Mods: Black Westin Bull Bar, AEM Bruteforce Intake, Stillen Dual Rear Exhaust, ReadyLift 2" Leveling, LE rims, BFG AT KO 305/65r18
Future Mods: Detroit TruTrac, Fender Flares Click here for pictures
