Re: Clean "stain" on a rim
Originally Posted by deepwatertitan
if you got room try using a clay bar.it is very safe and works great.you may need to buy a aggresive bar or if you cant find one aggresive enough just go over it several times with i lighter bar like the maguiers.i would try this first as some apc's can pit the rotors.
Claybar is not going to cut it on the mags... You're going to "F" up your bar.....Buying several bars for this job is also going to cost you $30.00+/-.....You have to think of the bigger picture. Either chemically release the stain from the metal through a reaction (non acid cleaner) or lightly rub it off with a "finer"metal.... Like "0000" (4 aught) steel wool.
Butyls, caustics and acids will attack the metal and although they will clean the stains...they will etch the metal and create the opportunity for corrosion the inhibit the metal in the near future... Just my opinion
Or you can try to some home remedies...Good luck with that.....
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
