Go Back   Nissan Titan Forum > Titan Discussion > Detailing & Truck Care
Detailing & Truck Care Discuss detailing techniques and products for your truck here!
Old 08-05-2008, 04:38 PM   #1 (permalink)
cleaning cabin air filter
Does anyone knows where to buy a cleaning product to soak or clean the cabin air filter? I have read that a spa cartridge cleaner will do the trick. Just soak it for hours then blow dry it before putting it back in. Don't know where to get it though...Any suggestions and where to get the cleaner is greatly appreciated.
tenshadowsun is offline   Reply With Quote
Old 08-05-2008, 05:11 PM   #2 (permalink)
HRTKD's Avatar
Re: cleaning cabin air filter
I probably cut some corners but I used Dawn dishwashing soap. It didn't seem to cause any problems.
Jim
Old 08-05-2008, 05:34 PM   #3 (permalink)
Thanks, Jim. I will do that.
Old 08-05-2008, 10:00 PM   #4 (permalink)
Supporting Vendor
P's Titan's Avatar
if you check out this bottom of this page there is a section called Similar Threads
Check those for your answer.
Old 08-06-2008, 01:26 AM   #5 (permalink)
My filters are charcoal gray. I keep thinking it's suppose to be all white. I have an 08 TITAN SE CC. I guess it came with it. Anyone knows for sure there are charcoal gray ones?
Old 08-06-2008, 01:27 AM   #6 (permalink)
Thanks P Titan....
Old 08-06-2008, 12:05 PM   #7 (permalink)
cneary812's Avatar
No, they are supposed to be white, but it doesnt take long for them to turn to the dark side
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is offline   Reply With Quote
Old 08-06-2008, 11:24 PM   #8 (permalink)
I left it soaked with dish detergent and tub & tile cleaner for six hours in warm water. It is still charcoal gray.
Cleaning Cabin Air Filter scr38 Titan FAQ & Howto Area 42 12-03-2008 12:33 PM
cabin air filter missing von Titan General Discussion 16 07-23-2008 01:28 PM
?? about cabin air filter... Arkdriver Titan Parts & Accessories 13 05-01-2008 10:30 PM
Cabin Air Filter ttugrad95 Titan General Discussion 9 06-06-2006 09:26 PM
cabin air filter jhromy Titan General Discussion 2 11-22-2004 07:59 AM
