Go Back   Nissan Titan Forum > Titan Discussion > Detailing & Truck Care
Detailing & Truck Care Discuss detailing techniques and products for your truck here!
View Poll Results: Should you undercoat with OIL or not
Yes 0 0%
No 3 75.00%
Using OIL 0 0%
Using rubber Undercoat or othe rust protection 1 25.00%
Voters: 4. You may not vote on this poll
Old 08-15-2008, 08:42 AM   #1 (permalink)
Undercoating
Hi I am new to this Titan Forum!
Just bought a new Titan 4x4 LE crew cab and am very pleased with it so far I have always drove 150 Ford's 4x4 so looking forward to this Titan lasting as long as my fords did.
As for undercoating I use a oil bath (Spray) using summer grade chain saw bar oil it is thick and sticks ( have you ever seen a chair saw bar rust ) ?
Have been using this on my last 2 fords and get 12 years out of each with original paint and no rust. Living in eastern Canada we use alot of salt on the road ways from Nov until April. In the spring I still give the underside a good pressure wash and then before fall spray the chain saw bar oil under (making sure to get in the wheel wells fender folds.
Spray on rubberized coatings tend to cover the rust and do nothing to kill it. Over time it will chip or peel and end up trapping salt and making your bus rust faster than if it had not been undercoated!
The best thing some of us up here have found is quality bar and chain oil. Do not get the cheap stuff. Agway or Husquarvarna seem to both use similar formulas. That is a mixture of phosphoric acid, oil, and paraffin. The phosphoric kills the rust. In fact the rust will turn black within a week. The oil and wax leave behind a sticky residue. This treatment also has the advantage of lubricating all joints, etc...
When looking to buy bar and chain oil, READ THE LABEL. Although it won't give you the ingredients, it should say something like: High adhesiveness, high oiliness, High Film Strength, Anti-Rust.
The best way we have found to apply the bar and chain oil is with a 3M Rocker Schutz gun and an air compressor at about 50-60 PSI. Atomizing the oil helps to make this a quick job as well as makes it possible to spray into doors, rockers, etc.
This stuff will evaporate/dry to some extent and leave a thin film behind.
I do my cars twice a year. In the fall, and also in the spring.
It's a good idea to pressure wash your ride and let it dry before undercoating. Spraying the oil on top of mud won't do much good...
I spray all sheet metal, joints etc underneath, and also spray in the rocker panels, doors, etc.
Would you rather have salt water or oil in them door seams ? Remember you'll be splashing up slush that seems to get inside all seams (this salt mix is not nice !)
Unlike the rubberized stuff that does nothing to kill rust, you get a chemical reaction from the bar oil with the metal which forms a protective oxide.
This treatment is for cars driven daily in the rust belt.
Considering the cost ($5 a gallon) this is economical. If you are judicious in applying this stuff, one gallon is all you need.
Just my thoughts
ffd172 is offline   Reply With Quote
Old 08-15-2008, 03:02 PM   #2 (permalink)
Skyboi's Avatar
Re: Undercoating
LOL!!!! Please tell me It's April 1st.......... You have to be Joking.
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Undercoating??? Ruffneck Boy Titan General Discussion 16 08-13-2008 03:06 PM
UnderCoating Yomama Titan General Discussion 9 04-03-2005 05:12 PM
Rubberized Undercoating?? tmoran Titan Interior Discussion 4 03-05-2005 10:29 PM
Acoustic Undercoating Help titanwild Titan General Discussion 11 02-24-2005 04:56 PM
undercoating Truck41 Titan General Discussion 1 05-12-2004 11:48 AM
