Go Back   Nissan Titan Forum > Titan Discussion > Detailing & Truck Care
Detailing & Truck Care Discuss detailing techniques and products for your truck here!
Old 07-05-2009, 08:44 PM   #1 (permalink)
Dirtytitan's Avatar
Angry Headlight lens restore question.....Help!
The headight lens on my wifes altima were starting to get crappy looking. The oxidation was getting pretty bad so I decided to get some Meguiar’s PLASTX, heard and read that it worked well. Did as insttructed and wow the oxidation is gone. However, the lens look just as bad now cuz they are all scratched up now. Has anybody else used this stuff on there lens? Does anybody have any ideas as to what i can do now? I dont think they need to be replaced but i will if i have to.
2006 Crew Cab 4X4 SE Big Tow
Performance Mods: 2* Timing Advance, AEM Brute Force CAI, Banks Monster Exhaust, Hypertech Max Energy 87 tune
Audio Mods: Alpine Type R Door speakers, Boston Acoustics S35 3.5" 2-way Speakers in the dash.
Other Crap: 8000K HID lows beams, B&W Tow and Stow adjustable Tri ball hitch, Burn out switch, Prodigy brake Control
Dirtytitan is offline   Reply With Quote
Old 07-05-2009, 08:53 PM   #2 (permalink)
Supporting Vendor
P's Titan's Avatar
Re: Headlight lens restore question.....Help!
Adam's has some products that will work.
Take a look at Junkman's video he did. Adam ( the owner, also did one )
The New Adam's Focal Pads - Headlight Haze Repair - Adam's Polishes Forums
These products are also good for your paint as you may have some scracthes you may want to rid of as long as there not to deep.
I did this demo in NC ( no vid but think there was pictures taken ) and the results were amazing. Only took about 5 to 10 minutes.
Products to use..
http://www.adamspolishes.com/p-430-a...g-kit-new.aspx
http://www.adamspolishes.com/p-36-ad...-clay-bar.aspx or this
http://www.adamspolishes.com/p-37-ad...ray-combo.aspx
http://www.adamspolishes.com/p-97-ad...ar-polish.aspx
http://www.adamspolishes.com/p-87-ad...er-polish.aspx
Again.. this is not just for the headlights. These will restore the headlights BUT will also benefit use on your paint as well.
my mods list
USE DISCOUNT CODE FOLGER
FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
P's Titan is online now   Reply With Quote
The Following User Says Thank You to P's Titan For This Useful Post:
Dirtytitan (07-05-2009)
Old 07-05-2009, 08:55 PM   #3 (permalink)
Dirtytitan's Avatar
I was expecting P's Titan, anybody else.
Old 07-05-2009, 09:17 PM   #4 (permalink)
Skyboi's Avatar
Yeah man.... Just buff it. Grab a sponge with a little glaze on it and you'll have a new looking lenz in less than 5 mins....I prefer a variable instead of a random orbit for this job.
Look at it this way...What do you have to lose if you ef it up? The light is already jazzed so give it a shot.
1. squirt a 1/2 oz of glaze on an applicator and spread it thin and evenly on the lenz.
2. grab your buffer (will work with a random) and have at it. nice and even coverage till the material is dried and almost all removed.
3. wipe away any excess and you're done.
This is not a big or expert project....Go for it
Good luck.
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Old 07-05-2009, 10:31 PM   #5 (permalink)
Dirtytitan's Avatar
Good luck.
Great thanks! Just one question. What product should i use? let me know and ill pick it up after work.
Old 07-06-2009, 06:15 AM   #6 (permalink)
Skyboi's Avatar
Honestly....you could grab any off the shelf liquid cleaner wax or 1 step product.
Either Maguire's or Mother's ....The cleaner types will give you a mild abrasive that should lift the oxidation off without being too difficult to control.
If you don't see the desired results after the first pass.....hit it again till you do. Finish it off by buffing your wax on and off....You'll be fine.
Hey......Let us know how you made out.
Pop Pkg * Tow Pkg
Fogs
The Following User Says Thank You to Skyboi For This Useful Post:
Dirtytitan (07-06-2009)
Old 07-06-2009, 06:40 AM   #7 (permalink)
Dirtytitan's Avatar
Ya man will do. I have a maguires step 1 polish in my garage, so after work ill give it a go. I'll even try to post some pics.
Old 07-06-2009, 07:33 AM   #8 (permalink)
Banned
Wetsand those suckers. Since you've cleaned them up with PlastX already, and removed the oxidation and grime, now you need to smooth the plastic down. Go to the store and get some 800, 1000, 1500, and 2000 grit wet sandpaper. Throw it in a bucket of water overnight. Then wetsand them starting from coarse to fine. After you wetsand them and they're good and smooth, they are going to look a bit hazy. Then take a powerball for paint (trust me, it works), with a bit of polish, smear the polish around the headlight before turning on the drill to reduce slinging, and polish the light out with the powerball. After you get that sucker crystal clear you then run into a dilemma...how to keep it from happening again. You could get the 3M film to cover the headlight. It works, it relatively cheap, and if it gets messed up, you just peel it off and replace it. That would be my choice. Others like to spray the lights with a few coats of clear for a bit more durability. My problem with that is the fact that in a year or so, you are just gonna wind up sanding and polishing again. The choice is yours, but if it were my car, I'd put the 3M protective film on the lights once you get them polished out.
And if you don't want to go out and buy everything separately like I have listed, you can also buy this:
Diamondite® Clear Plastic System Kit cleans, polishes, restores headlight lenses. Diamondite plastic polish scratch remover for headlights.
it's not 3M, but diamondite makes some great products, and that kit has everything you will need.
jjski78 is offline   Reply With Quote
Old 07-06-2009, 09:35 AM   #9 (permalink)
HRTKD's Avatar
I used a polish to remove the glaze from my '91 Ranger headlights. See post #6 in this thread: head lights - Nissan Titan Forum: Club Titan Forums
Jim
Old 07-06-2009, 10:01 AM   #10 (permalink)
Skyboi's Avatar
Just checked that post....pretty nasty headlight there. A few passes with the polish and done.
Well done
Pop Pkg * Tow Pkg
Fogs
Old 07-07-2009, 08:09 PM   #11 (permalink)
Dirtytitan's Avatar
So after jumping in the bed last night this was the thought that i had as well. Wetsand those sucker then do the polish. So thats what i did. Except instead of just buying the sandpaper i bought a 9 dollar wet sand headlight kit thats made by turtlewax. Worked like a charm. Before and after pics didnt turn out.
Thanks to all those that replyed.
Headlight Question nickel_whore Titan Parts & Accessories 0 12-13-2008 06:54 PM
headlight question windermeretitan Titan General Discussion 6 12-10-2008 10:04 AM
Another headlight question...PLEASE HELP! johng_30 Titan General Discussion 26 01-26-2008 06:03 PM
Headlight question 2007 TITAN LE Titan General Discussion 21 01-05-2008 07:57 AM
headlight question titanical Titan Parts & Accessories 3 04-06-2007 04:11 AM
