Nissan Titan Reverse/Backup LED Bulbs! Several Model Options! Ships Same-Day - Nissan Titan Forum
post #1 of 57 (permalink) Old 12-16-2014, 09:09 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
iTrader Score: 1 reviews
Arrow Nissan Titan Reverse/Backup LED Bulbs! Several Model Options! Ships Same-Day
Nissan Titan Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Titan's reverse light or backup light bulb (921 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 921-sized LED bulb, for perfect fitment in all Nissan Titan Model Years.
Bulb Design
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Fitment. All three bulbs use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP5: (92 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
The Following 4 Users Say Thank You to Diode Dynamics For This Useful Post:
El Mamito USMC (11-30-2015), gweasel77 (09-21-2015), John Alistair (03-13-2017), Kronos1965 (02-25-2015)
Advertisement
post #2 of 57 (permalink) Old 12-18-2014, 01:08 PM Thread Starter
Supporting Vendor
Good vs. Bad LED Bulbs: Testing Current
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
post #3 of 57 (permalink) Old 12-23-2014, 07:13 AM Thread Starter
Supporting Vendor
How LED Bulbs Are Measured: Integrating Sphere Overview
Nick C.
The Following User Says Thank You to Diode Dynamics For This Useful Post:
post #4 of 57 (permalink) Old 01-05-2015, 06:52 PM
Chevymanrc's Avatar
iTrader Score: 11 reviews
Re: FS: BRIGHT Reverse/Backup LED Bulbs! Hi-Power / CREE Models, Ships Same-Day
If you don't mind send me a quote for the different models. Thanks
07 4X4 CC LE BT OR
2.5" Leveling Kit
2010 LE 20's
Nismo CAI
JBA Ceramic LTs
UpREv Tuned
2.5" SS Catted Cajun B-Pipes
JBA Catback (Borla 40944 Swap)
Airlift Airbags
20% Tint
Headlight mod
Armaden LED interior
Chevymanrc is offline
The Following User Says Thank You to Chevymanrc For This Useful Post:
Diode Dynamics (01-15-2016)
post #5 of 57 (permalink) Old 01-06-2015, 11:40 AM Thread Starter
Supporting Vendor
Please contact us for more information: Contact@diodedynamics.com
Thanks,
Nick C.
post #6 of 57 (permalink) Old 01-13-2015, 09:42 AM
iTrader Score: 0 reviews
Put these in my reverse lights and they sure helped with the back up camera in the dark. The camera picture is much better now.
10MMGlock is offline
The Following User Says Thank You to 10MMGlock For This Useful Post:
Diode Dynamics (10-16-2015)
post #7 of 57 (permalink) Old 01-13-2015, 10:13 AM Thread Starter
Supporting Vendor
Glad to hear it! Thanks for ordering with us
Did you take any before and after pictures to compare?
Nick C.
post #8 of 57 (permalink) Old 01-14-2015, 06:16 AM
Nick C.
I should have but it was cold and dark when I was putting them in and did not think about it. Will be ordering some for the bed lighting inside the tailgate as well.
Diode Dynamics (01-14-2015)
post #9 of 57 (permalink) Old 03-12-2015, 09:08 AM
BernieMac's Avatar
Garage
iTrader Score: 2 reviews
Just wanted to say I ordered the XP50 reverse lights and they make quite the difference. I couldn't get my phone to take pictures properly in the dark, but it is dramatic.
I would say the usable distance visible back from the truck is now twice as far.
I'd highly recommend these if you are looking for a plug and play 5 minute way to get some additional visibility when backing up.
2008 Titan CCSB XE 4x4
Performance:
UpRev! Ceramic coated JBA LTs, Cajun catted b-pipes, Cajun Y-pipe and catback exhaust, Gibson 420887 muffler, Vibrant UQ and Gibson black ceramic tip.
Suspension:
Bilstein 5100s middle perch.
BernieMac is offline
The Following User Says Thank You to BernieMac For This Useful Post:
Diode Dynamics (03-12-2015)
post #10 of 57 (permalink) Old 04-10-2015, 07:28 AM Thread Starter
Supporting Vendor
Re: FS: Titan Reverse/Backup LED Bulbs! Hi-Power / CREE Models, Ships Same-Day
Here's a recent comparison from our 2015 Nissan Xterra Pro-4X testing:
The Xterra uses the same bulb size as the Titan
Nick C.
gweasel77 (09-21-2015), QABAMF88 (11-25-2016)
post #11 of 57 (permalink) Old 06-09-2015, 02:43 PM
El Mamito USMC's Avatar
iTrader Score: 8 reviews
what lights you have for the rear cab? the one that goes on the third brake ligth
Zorros Racing...
#123A Score Baja 500 FINISHER!!
This is not for woosies”
“Everybody play by the same rules, they all pay the same entry fees, I want to make sure that our hardcore, grassroots guys are always in Score, there’s a place for them”
-Sal Fish
Sponsors:
High end uniform
Suspension Specialist
Case savers, Chain Guides,
Supplements for endurance racing
Join the
travel to exotic lands, meet exciting unusual people and kill them..
El Mamito USMC is online now
post #12 of 57 (permalink) Old 06-10-2015, 06:31 AM Thread Starter
Supporting Vendor
The cargo lights should be a 921-bulb size, and a 194 bulb will fit the third brake light location. Here's an example of our 921 bulbs in the cargo light location:
Our HP5 (Red) is a great option for the third brake light
Nick C.
El Mamito USMC (06-10-2015), gweasel77 (09-21-2015)
post #13 of 57 (permalink) Old 06-10-2015, 06:50 AM
^^ great but those are the ones on the sides , inside the rear brake lights, correct?
and how much for a set for the cargo and the third brake light?
Zorros Racing...
-Sal Fish
Sponsors:
High end uniform
Join the
post #14 of 57 (permalink) Old 06-10-2015, 07:30 AM Thread Starter
Supporting Vendor
Right, they are the outside lights
The inside light is typically a 921/194 bulb size as well
We have a variety of bulb model options for differing amounts of brightness on each location.
The pricing depends on which bulb model options you select
Nick C.
post #15 of 57 (permalink) Old 06-26-2015, 06:29 PM
Nick C.
I want the XP50, the brightest ones.. pm me..
Zorros Racing...
-Sal Fish
Sponsors:
High end uniform
Join the
The Following User Says Thank You to El Mamito USMC For This Useful Post:
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Ultra bright, Super Wedge LED bulbs for Park, Brake, and Turn retrosolutions Retro-Solutions 14 05-26-2016 02:01 PM
Reverse backup light with Pioneer head unit and backup camera jpower9 Titan FAQ & How to Area 27 03-23-2013 07:50 PM
Color matched windshield cowl & LED turn signal and reverse bulbs. SATXTITAN Buy/Sell 12 09-09-2011 08:59 PM
anybody know of a conversion from stock halo bulbs to bright blue hid? CLAREMONTTITAN Titan General Discussion 0 03-11-2008 11:06 PM
You may post new threads
You may post replies
