Trailer connector problems - Nissan Titan Forum
Electrical & Wiring Forum for discussion of all your Electrical & Wiring troubles and needs. Sponsored by Optima Batteries.
post #1 of 10 (permalink) Old 03-10-2012, 06:34 PM Thread Starter
iTrader Score: 0 reviews
Hello,
I just had a electric brake controller installed in my new Pro 4x and the Technician tested it. It showed to be working fine but the RT Turn signal is not working at the Trailer connector on the Truck. We used the Factory wiring harness that came with my new Truck.
Everything works except the RT Turn signal. Can anyone point me in the right direction as to where to look for the problem? Heck it's a new Truck just 30 days old. You would think everything would work..
Thanks for any and all replies.
Bud
buzzard is offline
Advertisement
post #2 of 10 (permalink) Old 03-10-2012, 08:59 PM
chadp82's Avatar
iTrader Score: 4 reviews
A lot of trailer light problems are due to a bad ground. Sometimes its tough to chase down. Sorry i'm not more help
05 LE Crew w/ Offroad Package
Bilstein 5100's; 1" Rear Lift Block & 1.5" Strut Spacer
BDPP (2° Advance, WOT removed, Regular Tune)
JBA cat back, Cajun Catless B Pipes
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
A glass of beer shortens your life by one minute, a glass of wine by two minutes, and a day of work by 7 to 10 hours
America!!! (Designed by geniuses, run by idiots)
chadp82 is offline
post #3 of 10 (permalink) Old 03-10-2012, 10:28 PM
loufish's Avatar
iTrader Score: 11 reviews
Re: Trailer connector problems
Search thru the towing section because this has been discussed at length and in detail....
PRG Performance Kit w/SAW's
Rear Bumpy-Bumps
35" General Red Letter Grabbers on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
loufish is offline
post #4 of 10 (permalink) Old 03-11-2012, 03:50 PM
iTrader Score: 8 reviews
pull the conectors apart and make sure the pins seated correctly
Beaver Commander
2004 Armada LE
Deepwater Blue, Interior Leds,Reverse Leds, Tag Leds, Curt Discovery 51120 Brake Controller, Led Taillights, Weathertech Front row set, Led Fog Lights,Paracord Handles
porkchop2245 is offline
post #5 of 10 (permalink) Old 03-11-2012, 04:19 PM Thread Starter
Originally Posted by porkchop2245 View Post
pull the connectors apart and make sure the pins seated correctly
Are you talking about when the Trailer is connected to the Truck? If so, I haven't hooked up the Trailer yet. The Trailer Receptacle on the Truck has been tested with a Test light. No power TO the Receptacle on the RT Turn signal blade in the plug. I feel the problem is under the Hood but can't rule anything else out at this point.
buzzard is offline
post #6 of 10 (permalink) Old 03-11-2012, 09:38 PM
Under the truck trace the harness back from back to front there is a large connector under the truck
Sent from my ADR6350 using AutoGuide.com App
Beaver Commander
2004 Armada LE
post #7 of 10 (permalink) Old 03-25-2012, 04:47 PM Thread Starter
Took my pro 4x to dealer to be checked out on why the Rt Turn Signal don't work on the Trailer receptical.. They said the BCM was bad, and ordered one. Been a couple weeks now waiting for part to arrive. Called Dealer and they told me it should be here this coming week. I sure hope so, and really hope it fixes the problem.
Going to go camping shortly and need the lights workin correctly.. Anybody else have a BCM go out and cause this problem?
2012 Nissan Titan CC Pro 4x
Smoke, Premium & Luxury Package, Big Tow
BullyDog GT Tuner
buzzard is offline
post #8 of 10 (permalink) Old 07-22-2012, 07:41 PM
cannot find the plug and play for the electric trailer brake controller, have looked everywhere seems like, now have the airbag lite flashing from unpluging conector behind the kickpanel beside the park brake.
timovercash is offline
post #9 of 10 (permalink) Old 07-22-2012, 07:45 PM
my 2009 titan has tow package and cannot find trailer electric brake plug and play
post #10 of 10 (permalink) Old 07-25-2012, 07:39 PM
loufish's Avatar
Ok...your brake controller does not effect your trailer turn signals or brake lights....BUT there is a relay for that circuit....
Rear Bumpy-Bumps
Born 9/2004
2002 Honda XR650R
loufish is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
7-Way and a 4-Way covered trailer connector Relocation mxracer111 Titan Towing & Hauling 1 07-12-2009 07:28 PM
7 Pin Trailer connector GrotonTitan Titan Towing & Hauling 12 06-21-2009 05:56 AM
trailer wiring connector? rgrtitan Titan Towing & Hauling 12 01-31-2008 09:34 AM
Non BT, trailer wiring connector mount Bentleyguy Titan Towing & Hauling 8 10-09-2006 06:02 PM
trailer light connector? oktex88 Titan General Discussion 1 09-04-2005 11:02 AM
You may post new threads
You may post replies
