Transponder coding? - Nissan Titan Forum
Electrical & Wiring Forum for discussion of all your Electrical & Wiring troubles and needs. Sponsored by Optima Batteries.
post #1 of 24 (permalink) Old 08-07-2012, 11:40 AM Thread Starter
iTrader Score: 2 reviews
Transponder coding?
I have only one ignition key for my 2008 Titan and wanted to obtain a second one for emergencies. I purchased one and have programmed the remote opening/closing but need to have it coded so that it will actually start the vehicle.
My main dealer have refused to do this and so, I need to find a way to do this myself, or bypass the system entirely. Does anyone know hot to do this, or even if it is possible?
Thanks in advance
Twenty years from now, you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
baznicholson is offline
Advertisement
post #2 of 24 (permalink) Old 08-07-2012, 11:43 AM
dubyam's Avatar
iTrader Score: 0 reviews
Re: Transponder coding?
As long as you can prove ownership (title, registration, etc.) you should have no problem getting a good locksmith to program this for you. If you can't prove ownership, you have other issues.
dubyam is offline
post #3 of 24 (permalink) Old 08-07-2012, 12:09 PM Thread Starter
Thanks for the quick reply,
I have all the docs for the truck and can prove ownership 100%, but the locksmiths here do not program keys at all...
I've contacted Nissan USA to see if sending the key, with the documents, to them for programming is an option. I'll advise on their response
post #4 of 24 (permalink) Old 08-07-2012, 12:14 PM
dubyam's Avatar
If you have the original key code tab (was on one of the keyrings from the factory - looks like a small aluminum tab with some numbers on it) you may be able to order a pre-programmed key that will match exactly, directly from Nissan.
dubyam is offline
post #5 of 24 (permalink) Old 08-07-2012, 12:22 PM Thread Starter
Nope - didn't get that when I bought her... Someone said the code may be on the ignition barrel?
post #6 of 24 (permalink) Old 08-07-2012, 12:30 PM
dubyam's Avatar
You might be able to get it via the VIN? Maybe not, but seems like that should link to the build sheet/code somewhere in the bowels of Nissan???
dubyam is offline
post #7 of 24 (permalink) Old 08-07-2012, 12:36 PM Thread Starter
OK, I'll give that one a go. I've sent all the info to Nissan, so hopefully they'll be able to do something...
Thanks again.
post #8 of 24 (permalink) Old 08-07-2012, 01:15 PM
Supporting Vendor
seymore4's Avatar
iTrader Score: 178 reviews
I had a buddy that wanted a new key for his G35, dealer wanted to charge him around $200 for the programming.. we ended up just flashing his ecu with Uprev and disabling NATs lol Can't lock you out if its turned off
seymore4 is offline
post #9 of 24 (permalink) Old 08-07-2012, 01:51 PM Thread Starter
Pardon my ignorance, but what's Uprev, and would this allow me to bypass the whole transponder chip issue?
post #10 of 24 (permalink) Old 08-07-2012, 01:53 PM
kdo2milger's Avatar
iTrader Score: 8 reviews
take it to Ace Hardware they should be able to clone it
Project NISMO
2012 CC PRO-4X
kdo2milger is offline
post #11 of 24 (permalink) Old 08-07-2012, 01:57 PM Thread Starter
I'd love to, but we don't have any in Panama... Perhaps a Spirit flight up to Miami may be in order. If I take the original and the blank, will they be able to do it in store?
post #12 of 24 (permalink) Old 08-07-2012, 02:02 PM
Supporting Vendor
seymore4's Avatar
Ace hardware can clone keys that trick NATS?? (Nissan Anti Theft System)
OP- Uprev is the ecu reflash tuner that most guys use, its different from a handheld like Bullydog or superchips in that its completely tuneable like a full standalone, but using the stock ECU. Its the only one that can permanantly disable DTC codes in the ecu (for headers n such) and one of the additional functions that protuners have access to is completely disabling NATS. Its necessary for engine swaps, using different ECU's, etc, but if you want to start your truck with an unprogrammed key turning off NATS would fix that problem as well.
seymore4 is offline
post #13 of 24 (permalink) Old 08-07-2012, 02:02 PM
kdo2milger's Avatar
if the store has the machine, ya...sorry didn't realize you were in panama till i looked at your location...
how about wal-marts? you got one? some of them have the clone machine too...
Project NISMO
2012 CC PRO-4X
post #14 of 24 (permalink) Old 08-07-2012, 02:07 PM Thread Starter
None of them either I'm afraid. I'll check to see if I can find a store with the necessary kit close to Miami International and take a flight up, or get a friend with Copa Airlines to do it on a turnaround...
The Following User Says Thank You to baznicholson For This Useful Post:
kdo2milger (08-07-2012)
post #15 of 24 (permalink) Old 08-09-2012, 08:41 AM
smon's Avatar
Do you have Lowes or Home Depot around you? Ace Hardware? Most of these places will have a transponder duplicator...although my local walmart said they couldn't do my 2011 (who knows if they are right).
Are you sure you asked every local locksmith? I found a guy who does unlocking and mobile key cutting. He can cut and program my key for $45. Extra keys are $5 a piece.
But worst case, send that key up here somewhere and it should be no problem. Probably looking at $80 max just by taking it to a dealer. My dealer said $15 to cut, $50 to program, and $30 for a key. I bought 2 keys off ebay for $12.
Mods: Custom Rock Sliders, LegitLED interior/bed lights and 55watt HID Hella 500s, Magellan 9055 nav bezel, backup camera, remote start, 2*advance, Goodolsen grounding kit, 100w hellaFF, complete sound deadening, RC UCA, 5100's middle setting, 1.5" front spacer, 1.5" rear spacer, DIY Window Tint.
smon is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Powder coding the OEM wheels? White Light Titan Wheels, Tires & Brakes 6 01-16-2012 05:47 AM
transponder keys gunner Titan General Discussion 0 10-03-2011 09:17 AM
WTB: Transponder chip kewlkarim Buy/Sell 6 07-10-2011 09:08 AM
WTB: uncut transponder key & FOB kewlkarim Buy/Sell 8 02-01-2011 05:07 AM
Transponder key? tcf_dk Titan General Discussion 5 12-25-2005 03:15 PM
You may post new threads
You may post replies
