Help. I recently installed a new wheel bearing and immediately after the install my abs and slip lights came on. No lights were on prior to. Decided to installed the original sensor. No change. So I decided to swap the new bearing and hub assembly with another new unit. No change. I'm stumped.
This was on the RF. Had autozone read the code and it said RF Wheel Speed Sensor.
Did some ssarching and found where the two wires connect to at the E125 connector pins 33 & 34. One of the wires shows continuity, the other does not. This leads me to believe that the wire is broken somewhere between points A & B.
What do you guys think? And if this is the case how do I fix it? The wire is all bundled up in the harness.
Ugh. I don't care about the ABS but this has me locked out of using 4wd.
