Any suggestions on how to run the wires for the led light bar from the roof and hood to interior. Also where did you mount the switch? What switch did you use?
I also purchased some custom rocker switched from OTRATTW and for $15 a piece, they look great. I'm getting my 50" LED bar mounted and wired this Friday and will post pics then. I can provide pics of the switches if needed.
from the roof, run it down the windshield behind the piece of rubber, you'll only see a small piece of wire from the light itself going into the windshield (it wont leak, its actually sealed and that piece of rubber just covers the gap) from there you can run it right under the pastic piece where the windshield wipers are, straight across to the battery and into the cab... im very OCD when it comes to neatness and wiring, i have a shop where i build hotrods... i look at some of the posts on here and what some of these guys do and some of them turn their trucks into real hack jobs with cutting things, and running wires where they dont belong and what kills me is they think it looks great! dont be that guy!! do it once and do it right
I plugged a bad lighter unit into my lighter socket ( the left one), now my lighter socket on the left dont work, but the one on the right does. also when i lock my truck the horn dont sound off when activating the alarm. Does anyone know what the problem might be. I checked the fuse and it looks good.
Related Threads
Nissan Titan Forum
3.9M posts
142.8K members
Since 2003
