Go Back   Nissan Titan Forum > Titan Technical Discussion Area > Future Titan Discussion
Future Titan Discussion This is an area to discuss the direction of the future versions of the Nissan Titan.
Old 04-09-2007, 01:41 PM   #61 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
Re: Future Nissan Titan Ideas/Discussion/Suggestions?
driver only keyhole.. all years i believe...
remember when cars needed door keys? what would i do without my fob!
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 04-09-2007, 01:46 PM   #62 (permalink)
etalian2005's Avatar
Send a message via AIM to etalian2005
and i would like to add, larger fenders to accomodate larger tires.
and keyless entry
ESCORT SOLO S2 RADAR DETECTOR FOR SALE!!!
2008 PRO-4X Black on Black 4x4 w/ Leather package, Big Tow, and Utility Bed
BlackJack
Mods:
Performance: Superchips FlashPaq - 93 tune, 18" Magnaflow Muffler
Suspension: PRG 1.5" Leveling Kit
Wheels & Tires: 20x9 Ballistic Offroad Jesters, 33x12.50x20 Toyo Open Country M/T
Audio: 2 12" RE Audio SE's, Sundown SAE-1000D amp, Tech12Volt Sealed Box
Accessories: 6000K McCulloch HID Lows, 6000K DDM Tuning HID Fogs, 20% front tint, 5% in the back, and 5% on top of windshield, Hardwired Valentine 1, RBP 4.5" Black Exhaust Tip
etalian2005 is offline   Reply With Quote
Old 04-09-2007, 01:50 PM   #63 (permalink)
Steamguy's Avatar
My '04 is a great truck, and has been for these nearly 60,000 miles, but I WOULD change a couple of things. I'll just keep my comments to the stuff that's not been posted already, with the exception of the axle stuff. You guys out there cratering diffys has me wondering, but I broke mine in the way the book said to, and it's quiet and works well.
Narrow down those stinking huge A-pillars! I have to lean right and left to see around the driver's side on our narrow and twisty country roads.
PUT A REAL TOW/HAUL MODE IN THE TRUCK. What's in there now, is totally useless. I've ranted in other threads about the useless Tow Mode. Enough said, here.
The tool box in the outside of the bed is a great idea, but make it strong enough to stand on! I'm an old f@rt and my knees won't stand stepping straight up on the bumper to get in the bed.
A thought on backup lights. We have technology that brightens cellphone displays in full sunlight, why not the same thing (real bright when it's pitch black) for backup lights? Wouldn't be that hard. A switch to turn them off when towing would be cool.
Nobody so far has mentioned how the gauges are almost invisible in bright light. Why not semi-analog indicators (like our gauges are) for gears and such? Such stuff isn't rocket science, but would add major stones to the cool factor.
Also, why not indicate what gear the tranny is REALLY in? Here's what I mean: Have an indicator that tells you what you've selected. Most times, it'll be OD. But have a second indicator that tells you what gear the tranny's in. This would be super-helpful for towing, when you want to hold the lower gear for just a minute longer to help with cooling.
I also don't think anybody's mentioned the heater ducting. Nissan needs to fix it so it actually warms your feet, and not your knees. Get a little older and have less-than-perfect circulation and warm/cool feet makes a BIG difference.
Since I'm talking about the heater, I for one would like to see better defrost/defog. Right now I have to crack a window to make the defroster work better. In my part of the country, humidity during the winter is a real problem.
And make the Big Tow mirrors so they come in closer to the body. I've already lost one to an idiot in a Ford who couldn't figure out that you're supposed to stay on your side of the yellow line. Or maybe the stupid trucks just handle that bad and he was trying to stay out of the ditch.
Long, I know, but maybe I covered points that haven't been made already.
Steamguy
Old 04-09-2007, 02:01 PM   #64 (permalink)
good points steamguy...
BlackJack
Mods:
Old 04-09-2007, 03:02 PM   #65 (permalink)
Yellomantis's Avatar
Originally Posted by helomech
My passenger door doesn't have a key hole.
XE passenger side doors have key holes. Especially the ones that have manual EVERYTHING. No power options at all.
2006 4X4 LE OR CST 7" Lift, RadFlo 2.5 coilovers, PRG Uppers, RadFlo 2.0 rears, Deaver 2.5 mini pack, 3" custom block, PRG traction bars, TC HD rear shackles, 2* advance, Custom Supertrapp exhaust, XE mirror covers and door handles, 17X8 AR Mojave Teflon's, 35/12.50R17 Toyo Mud Terrains, Bushwacker fender flares.
www.myspace.com/yellomantis
Old 04-10-2007, 07:27 PM   #66 (permalink)
Brundy's Avatar
All CC's have power windows so not everything is manual. And yes my XE has a pass side key hole but it sets off a factory alarm when I use it. I want to talk to the mental pygmy that thought up that.
Brundy is offline   Reply With Quote
Old 04-10-2007, 08:57 PM   #67 (permalink)
Are you sure all CC's have PW?
Can't you just turn the alarm off before you unlock the pass side door? Problem solved...
Old 04-11-2007, 12:42 PM   #68 (permalink)
SIMBOSS's Avatar
Send a message via AIM to SIMBOSS
How about one of these!
Oh and better interior materials.
____________________________
Ted
04 LE,CC, 4X4 OR/BT Brawn Red
B.O.D. 04/04/
05 SE 4X4 OR BT Pathfinder Black (girlfriends)
95 Wellcraft Nova Spider 454 Magnum (350 hp)
73 mph (GPS) It really likes the gas too!
89 SE V6 hardbody w/320,000 miles used to pull
my boat.......(needed a bigger truck).
Options in order:
2 degree timing advance thanks to Titanblue,
Fram AirHog, Nissan Hood Protector, Truxedo, Nissan XM receiver (mounted under steering wheel area as per Forum recommendations....worked like a charm)
with non-Nissan much smaller Xm antenna (mounted through Third brake light hole...piece of cake), and last....so far, PRG leveling kit (love it....no problem install after I realized that I really should listen to PRGreg about disconnecting the anti sway bar)
SIMBOSS is offline   Reply With Quote
Old 04-11-2007, 11:51 PM   #69 (permalink)
titan814's Avatar
1. bigger rotors
2. more hp/trq
3. performence parts
400hp LS6 CTS-V
titan814 is offline   Reply With Quote
Old 04-12-2007, 12:00 AM   #70 (permalink)
Leadsled124's Avatar
Hay EKOOL maby make a poll where you can click like 3 or 5 dots. then you could show it to nissan.
Anyways,
*Thicker paint, or good ol fasioned lead paint like the good ol days lol.
*Stronger Rearend
*BETTER INTERIOR MATERIALS (softer?)
*better hp/tq than tundra <----(notice "tundra" not capetalized, cause they suck LOL!!)
'06-Uprev/Stillen Longtubes/JBA Kat-bak/Injen/highflows/PGM/Trutrac...
Leadsled124 is offline   Reply With Quote
Old 04-13-2007, 01:47 PM   #71 (permalink)
54warrior's Avatar
1. Thicker paint-especially in the rocker and hood areas.
2. Entire rear window electric up/down slider standard on all CC's
3. Get rid of the Goodyear SR-A's
4. Wiring Harness connection (about a 60-pin) behind the RF wheel should be better protected and possibly mounted inboard on the frame.
5. Higher quality CHROME on the bumpers, both on the outside viewable area as well as the interior. Mine are rusted to heck all ready.
6. Rear End Woes
7. Improve Fuel Mileage
8. Better Skid Plates
2005 Nissan Titan CC SE 4x4
Old 04-14-2007, 10:32 PM   #72 (permalink)
Titan-ous's Avatar
Since just about everything is covered: A REMOTE STARTER
2004 SE CC - Canteen
Packages: Big Tow / Off-road / SE Popular
EBC 3GD SPORT Rotors and Greenstuff pads
Dale Earnhardt Jr Cannon wheels
Magnaflow dual rear exhaust
Volant Gen3 cold air intake
Trenz Billet Grill & Shorty antenna
ARE LSII bed cap
Silverstar lamps
Titan-ous is offline   Reply With Quote
Old 04-15-2007, 08:07 PM   #73 (permalink)
54warrior's Avatar
After driving 5 hours in the rain today, I feel they need to add 2 or 3 more settings for the intermittent wipers. They were consistantly either too fast or too slow, could not find a happy setting.
Old 04-16-2007, 07:32 AM   #74 (permalink)
Brundy's Avatar
As far as I know, all CC's have PW's. None of my paperwork shows it to be eqipped with an alarm. I didn't know it had any type of alarm until I opened the pass door with the key. The dealer says thats just how it is, tough luck.
Old 04-16-2007, 07:53 AM   #75 (permalink)
54warrior's Avatar
I think ALL mfg's should offer the rubber flooring as an option on ALL models of trucks.
Towing w/ Titan - New Discussion Topic/Category? Masa Titan Towing & Hauling 39 04-18-2007 07:26 AM
Stay Away From Future Nissan mbflorentine Titan Problems & Dealer Service 25 04-05-2007 06:04 PM
Future Titan Suggestions TiFu Titan General Discussion 0 08-16-2004 04:12 PM
For info only...No replys allowed..Tech Discussion w/Nissan CaliforniaTitan Titan General Discussion 0 05-17-2004 08:45 PM
Nissan Titan meeting discussion rrumaner Titan General Discussion 8 05-10-2004 11:05 PM
