Go Back   Nissan Titan Forum > Titan Technical Discussion Area > Future Titan Discussion
Future Titan Discussion This is an area to discuss the direction of the future versions of the Nissan Titan.
View Poll Results: What do you think about Tow Mode?
I never use it. I tow in 4, with Tow Mode OFF. 18 15.13%
I tow in 4 with Tow Mode ON. Seems to make a good difference for me. 44 36.97%
I use it, but I don't tow anything real heavy. 29 24.37%
I tow, but I don't use it at all. 14 11.76%
I kick it on around town because it makes the truck feel more 'sporty'. 14 11.76%
Voters: 119. You may not vote on this poll
Old 05-13-2007, 03:02 PM   #16 (permalink)
Learjet's Avatar
Re: Fix the Tow Mode - please
my 2006 in 4th with TM on will keep the converter locked until it is time to downshift. I tow at 65 mph on the interstate and would have to bog down below 60 before it unlocks.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 05-14-2007, 08:10 PM   #17 (permalink)
Smoke05's Avatar
I have an 05 and mine runs the same.
If your engine or transmission is over temping and you are towing with tow mode and in 4th gear, something is not right with your truck or your tranny temp gage. Mine is lucky to reach half way even in 90 degree weather towing my 7500lb travel trailer.
Smoke05 is offline   Reply With Quote
Old 05-18-2007, 07:42 PM   #18 (permalink)
debos titan's Avatar
i pulled a u-haul behind mine but i could not tell a difference. i bought the 2 chips from nissan and it seem's to do nothing for me.
debos titan is offline   Reply With Quote
Old 05-18-2007, 09:00 PM   #19 (permalink)
vipzach's Avatar
The chips(relays) are only for the trailer lights!
vipzach is offline   Reply With Quote
Old 05-24-2007, 12:17 PM   #20 (permalink)
UWSkier's Avatar
My beef with tow mode is it doesn't like to drop into a higher gear as early as it should when reaching the apex of hills. Mine seems to stay downshifted longer than I'd like. That motor has a ton of torque down low. Use it!
Hemi? I've got CHUNKS of Hemi in my STOOL!
'06 CC BT LE in Red Alert.
Airbox Mod, scAmsoil hi-flow filter, Bullydog GT, timing bump, Lorado Tonneau, 8000K 55w HIDs, Silverstar Hi's, Vent Visors, billet grille, axle vent mod, Revo's.
UWSkier is offline   Reply With Quote
Old 05-27-2007, 06:39 AM   #21 (permalink)
loufish's Avatar
After reading these posts, I've come to realize this:
The 2004 Titans seem to have a problem keeping the T/C locked at moderate towing speeds, while the later Titans don't seem to share this same issue..
Now, some of the guys here have stated that the tranny temps will go up unless they manually downshift, that sounds like the T/C is unlocked because that's were the heat comes from. Are these trucks having a problem keeping the T/C locked, but the owners don't know it?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 05-27-2007, 10:57 AM   #22 (permalink)
Steamguy's Avatar
I think you're onto something here. I've found that using Tow Mode is useless in my early '04 because the torque converter just won't lock at all. When I DON'T use Tow Mode, but instead just keep it in 4, everything's happy. Torque converter stays locked, RPMs stay low if you give it just a little gas.
And here's another way that mine appears to be different: I can have mine just set to 4 (Manual mode) and it acts just like a regular automatic, where it will downshift if the RPMs are too low, or if you punch it.
There were a number of changes in about July of '04. I would now bet that the ECU/TCU were part of them.
Steamguy
Old 05-27-2007, 11:36 AM   #23 (permalink)
Ghostface's Avatar
Just bought my 06 Titan and look forward to towing with it and seeing how she compares to the 04. I have a am pretty sure the 06 is going to have no problems with tranny temp. I too have had the same feeling based off of other forum postings about this tranny temp issue that it was more of an 04 model year issue
06 Titan 4x4 LE CC Blizzard, Big Tow, RF, sunroof, Side airbags, Rancho 4 inch lift, 20" rims, 35X13.5x20 Cooper STT offroad tires. Sirius, Volant intake, A.R.E. Hard Tonneau cover, and Tech12volt box.
Previous Titan
04 Titan 4X4 SE CC Black Big Tow, Offroad, Utility bed. Toys that were added DVD, Sirius, and ARE Hard Tonneau.
Ghostface is offline   Reply With Quote
Old 05-27-2007, 08:52 PM   #24 (permalink)
xtremerider954's Avatar
I have an 04 LE KC and have never had any temp issues when towing. I've towed everything from my car all the way from NC to FL with no problems to just using it for work pulling stuff. Love it
xtremerider954 is offline   Reply With Quote
Old 05-28-2007, 09:34 AM   #25 (permalink)
loufish's Avatar
1. Do recall how the T/c acted in 4th and 5th gear?
2. Are there any hills in FL?
Born 9/2004
2002 Honda XR650R
Old 07-05-2007, 07:32 AM   #26 (permalink)
Ghostface's Avatar
Just an update.
So pulled the camper out to the coast this weekend in the 06 and guess what? My temp never rose above 1/2. On this same trip towing same camper with my 04 I typically reached max temp at least 2 times if I was not paying attention to the guage every 30 secs or so.
Previous Titan
Old 07-27-2007, 01:02 PM   #27 (permalink)
I have a 04 and towing in the winter, I had 5 passengers, a bed full of luggage and towing a 6 place snowmobile trailer, which is prob about 6500 or 7000 lbs. I was having a problem getting the TQ converter to lock in 5th, I downshifted it to 4th and it was happy as a clam. Even on flat areas it wouldnt lock, now this was at about 70 mph, at lower speeds it didnt lock either, but it wasnt as much of an issue. Doing this did cause teh tranny to heat up, but not to the H, but to the line below which based on my understanding is the upper limit of normal.
x2thez is offline   Reply With Quote
Old 08-09-2007, 10:46 PM   #28 (permalink)
Jetboy's Avatar
I have an 05 and tow about 8,000#'s and 11' 3" tall. About 1/3 of my normal trip is with 6% or greater grades and temps in the triple digits and the tranny temp never goes over 1/2. Tow mode seems to work fine in those conditions, it is on the flats that I can take it or leave it, generally leave it.
05 KCLE Smoke Towing 05 Cherokee 30F
Jetboy is offline   Reply With Quote
Old 08-14-2007, 02:16 PM   #29 (permalink)
linycctitan's Avatar
I've never had an issue towing with my '06. We usually do 15-60 miles with 8500# of boat & gear and the tranny temp never climbs above the 1/2 way point on the gauge, and sometimes its 85-90 out w/ max a/c cranked, no temp issues at all.
Firefighters are always in heat!!
2006 Titan SE Crew Cab 4x4 Off-Road
Majestic Blue w/ Graphite & Gray Cloth
Utlity Bed Pkg, Big Tow Pkg
Mods so far: Buffalo Polished S/S Step Bars, Lund Polished S/S Interceptor Hood Sheild, Truxedo Lo-Profile QT Bed Cover, Whelen LED Emergency Lighting Pkg., 2" NCD Leveling kit w/bumpstops, 7'6" SnoWay 26 series Snowplow, LT285/70/17 GoodYear Wrangler ProGrade Silent Armor's, 60" Fire-N-Ice LED Bar
Freebie Mods: Air Box mod, Rear Axle Vent mod, Fog Light mod, 3 dents in tailgate
linycctitan is offline   Reply With Quote
Old 08-15-2007, 11:19 AM   #30 (permalink)
I have an 08 Titan with less than a 800 miles on it. I towed my pop-up last weekend up some mountain roads with no problems, I watched the trans temp and it stayed well below the the hot zone. I did take easy since it is in the break-in period. I very impressed with the power. Tons better than my old Durango.
tough-titan is offline   Reply With Quote
Tow mode: What is it actually doing? absolutbackus Titan General Discussion 31 04-09-2006 10:55 PM
tow mode NOT big tow Frequen.C Titan Towing & Hauling 18 02-07-2006 01:02 PM
OD and Tow Mode ???'s scubastud Titan General Discussion 5 07-21-2005 12:03 PM
Big tow mode? Voodoo Titan General Discussion 7 07-16-2005 04:21 PM
what does 'tow mode' mean for me? stick Titan General Discussion 6 02-05-2005 10:55 AM
