Go Back   Nissan Titan Forum > Titan Technical Discussion Area > Future Titan Discussion
Future Titan Discussion This is an area to discuss the direction of the future versions of the Nissan Titan.
View Poll Results: What do you think about Tow Mode?
I never use it. I tow in 4, with Tow Mode OFF. 18 15.13%
I tow in 4 with Tow Mode ON. Seems to make a good difference for me. 44 36.97%
I use it, but I don't tow anything real heavy. 29 24.37%
I tow, but I don't use it at all. 14 11.76%
I kick it on around town because it makes the truck feel more 'sporty'. 14 11.76%
Voters: 119. You may not vote on this poll
Old 08-19-2007, 08:45 PM   #31 (permalink)
milleniamarv's Avatar
Re: Fix the Tow Mode - please
Towing on Vancouver Island, BC last month noticed trans temp had climbed higher than normal after stopping for gas (ouch!). After clicking tow mode back on, trans temp returned to normal within a few minutes.
KC LE 4X4 Built 03/04, Sedona, Big Tow, XM Radio, Remote start, Billet grille, Advance bed cover, Chrome tailgate cover, '05 finned diff. cover, Armada air dam
Utah Highway 12
http://www.byways.org/browse/byways/2020/
milleniamarv is offline   Reply With Quote
Old 08-21-2007, 07:35 PM   #32 (permalink)
I chose the tow in 4 with TM on, but don't think that it does much. I have a late build 04 w/big tow and tow a travel trailer ~ 6500lbs. Not to discredit what some are towing, but towing a travel trailer with the same weight is different because the wind resistance is the major factor at cruise. I would personally like to see a TM setting that works in conjunction with the cruise control, because I have personally given up on using the cruise control while towing unless there is a tail wind. Seems like the cruise lags to much before reacting. I guess that it (cruise)could just be better. The TM could do more also.
PurdueTitan is offline   Reply With Quote
Old 08-23-2007, 08:16 PM   #33 (permalink)
Smoke05's Avatar
Not to be a nag, but you shouldn't be towing using cruise control. IIRC the owner's manual states this as well. It can be very dangerous as you have no direct, immediate control over the vehicle
Smoke05 is offline   Reply With Quote
Old 08-25-2007, 07:13 PM   #34 (permalink)
loufish's Avatar
Too late...you are a nag!
Towing with CC on is fine as long as traffic isn't too much, just like using CC any other time.
The manual states stuff to keep idiots from sueing them, not everything in there is dangerous...Ok some things are, but not everything!
I tow all the time w/CC on...I kill it when climbing hills and when traffic gets busy...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 05-05-2008, 11:29 AM   #35 (permalink)
07cajuntitan's Avatar
I chose "I use it, but I don't tow anything real heavy" as this sums it up perfectly for me. I can't feel any changes with it on or off, but I guess it has a purpose - so I use it. My 14' aluminum boat & trailer can't weigh more than 2000#. My estimate was 1500#. I tow in "drive" and do use the cruise control on the interstate & highway.
Truth be known - I haven't even thought to look at the tranny temp gauge - don't even know if I have one. Do they only come on the Titan's that have the big tow package?
2007 Titan SE KC 4x4 Granite --- Geaux Tigers!!!
07cajuntitan is offline   Reply With Quote
Old 05-05-2008, 12:32 PM   #36 (permalink)
Quartz's Avatar
I have an 06. Before my father died I would tow his restored cars to car shows for him. His favorite was a Studebaker. That car had a lot of steel in it and was solid as a rock (sorry Chevy). Car, trailer, tools, and other assorted stuff usually ran in the 7000 to 8000 Lb range. Now I mostly tow my boat. Total weight of the boat, motor, and trailer is well under 5000 Lbs.
I tow in 4th with the TM on. It gets Africa hot here in the summer but there are no hills. I have never seen my tranny temp gauge go over half way. I never paid much attention to the TC locking up but I will after reading this thread.
BTW, on the one hill around here I can feel my transmission braking when I coast down the hill.
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Old 10-03-2008, 12:33 AM   #37 (permalink)
Exclamation Re: Fix the Tow Mode - please
I have just finished a 9000 mile trip from Colorado to Alaska and return. My 07 CC LE with BT had no trouble with my 5000 pound travel trailer. I played with the Tow Mode on and off for weeks in my 2 month travels, and found that my driving style, and the roads of Canada and Alaska, usually worked best without TM.
Using cruise, I could hold speed and downshift for grades BETTER without TM, and when without cruise, I found the TM would NOT upshift at the top of a grade for the LONGEST time..... I finally gave up on the idea and went to no-TM, using the manual 4-5 shift to let me think I was contributing to the speed management (empty roads can be boring).
There was no road situation where I found Tow Mode to be clearly helpful.
What have I missed?? Early on, I was disappointed that I had to re-set TM as active each time I started the engine. Later, I came to realize that was probably a good thing.
greyfeather is offline   Reply With Quote
Old 10-03-2008, 02:48 PM   #38 (permalink)
Steamguy's Avatar
You found, like I did, that it really doesn't do much for cruising. I believe that Nissan changed the firmware to allow the torque converter to lock when using Tow Mode. The only thing I've found it to be good for is when you're towing light at low speed like in a traffic jam and you want the engine speeds to be higher to keep things cooler.
You haven't missed a thing. Towing in 4, you can do better at managing the engine speed yourself.
Steamguy
Old 10-03-2008, 07:09 PM   #39 (permalink)
HRTKD's Avatar
I have this problem without TM going up long mountain hills.
Where in Colorado are you at?
Jim
Old 10-04-2008, 03:31 PM   #40 (permalink)
HRTKD, my Colorado location is out in the 'buffalo country', the rolling plains of Elbert County. SouthEast of Denver. I also spend time in North Texas, and am presently near "Big D".
Old 10-04-2008, 04:58 PM   #41 (permalink)
HRTKD's Avatar
Cool, I cruise through the teeming metropolis of Elbert a few times a year on my way to the Boy Scout camp just South of there. I'll honk at every Titan in Elbert County and eventually you'll be one of them.
Since I'm more Colorado-centric than Texas-centric (native of CO but lived in Houston for 13 years) is Big D for Denver?
Jim
Old 10-04-2008, 11:16 PM   #42 (permalink)
Spoken like a good Colorado guy.....
No, there's only one Big D that I know about, and that's Dallas (Texas, of course....)
Old 10-05-2008, 10:38 AM   #43 (permalink)
loufish's Avatar
That's the bottom line for most Titan owners....It's so "weak" it's practically useless...
Born 9/2004
2002 Honda XR650R
Tow mode: What is it actually doing? absolutbackus Titan General Discussion 31 04-09-2006 10:55 PM
tow mode NOT big tow Frequen.C Titan Towing & Hauling 18 02-07-2006 01:02 PM
OD and Tow Mode ???'s scubastud Titan General Discussion 5 07-21-2005 12:03 PM
Big tow mode? Voodoo Titan General Discussion 7 07-16-2005 04:21 PM
what does 'tow mode' mean for me? stick Titan General Discussion 6 02-05-2005 10:55 AM
