Go Back   Nissan Titan Forums > Off-Topic Area > Hunting / Fishing
User Name
Password
Hunting / Fishing If you are interested in Hunting or Fishing, this would be the place to discuss it.
AR-15- Bushmaster or Colt? - being discussed at Nissan Titan Forums in the Hunting / Fishing section.
Old 03-03-2008, 11:07 AM   #76
Skyboi
Skyboi's Avatar
Re: AR-15- Bushmaster or Colt?
Originally Posted by Energizer
soooo... you decide on a plan yet?
You can always get more than one... or get a couple uppers to change the configuration around as you please....
oh, and you can get a .22LR conversion kit if you get a .223/5.56 (get a 5.56mm chamber), like the Ciener for example-- drops right in (replaces bolt, carrier, and has chamber adapter) and uses .22LR mags which are $20-$35 depending on where you go... or much more for metal ones made by Ciener....
Based on the link that Ericcartman posted a few pages back http://forums.officer.com/showthread.php?t=81462
I'm looking at the CMMG AR-15. The guy on this forum really seems to know his sheeit. I'll be heading out to my local gun dealer this weekend to put my hands on a few. I also have a piece of equipment I have to sell. I'll be using the cash from that to get the AR-15.
I really like POSSUM's set up also.
I'm still not skilled enough to figure out what i'd need to build one. Uppers? Lowers? I'd probably wind up killing myself.
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Old 03-03-2008, 11:41 AM   #77
Energizer
Energizer's Avatar
pretty simple to build. you can also order the top half, and the lower half, SEPERATELY, to make it cheaper.
Energizer is offline   Reply With Quote
Old 04-11-2008, 10:54 AM   #78
Fat Possum
Fat Possum's Avatar
AR guts...nothing tricky here
SB,
Sorry it took so long to get these up, thanks for the skinny on the clay bar stuff, btw.
There's no magic to an AR, 'cept the way they shoot. The original, "you can tell its mattell" black rifle was designed for grunts....therefore, everything I tore down in the below pics was done with a 5.56 NATO round as my only tool. (you can take the front quad rail off with an allen wrench, and the pistol grip with a screwdriver, but I was limited on time taking these.)
Here's the AR prior to takedown:
first off, You push the rear detent on the left side with the tip of the round, exposing the other side where you can grab it and pull the detent pin out to full stop:
next, do the same for the foward detent, (optional, makes barrell cleaning easier....early AR's (SP1's) wouldn't break at the front without tools; making it more difficult to swap lower recievers.)
I've also pulled out the charging lever to show you how the bolt slides out:
this pic just shows how the rear buffer spring comes out. (hot gas runs from the end of the barrell back thru the gas return tube, just under the front sights, and pushes the bolt back into the buffer spring....this is why AR's don't have folding stock options like the piston driven AK's.
This is the guts of the AR...the only thing you're not seeing is the barrell and the gas return tube, (shrouded by the front quad rail.) The bolt, firing pin and all that comes apart super easy, (using the tip of a round,) and is nothing complicated.....(like say, a .22 speedmaster!)
This is the whole diddy...carry handle option or scope, quad rail paddles, sling, et al.....minus any laser, surefire, bayonet, or grenade launcher options
I'm still lobbying for you to go with the Stag...they make the M&P for smitty and my buddy just got a Left handed model, (they're the only lefty AR makers?)....he says the fit and finish is on par with my S&W and the Colts we all love so much.
The big caveat I'd give you when playing with AR's is only shoot NATO 5.56 ammo. .223 remington is not milspec and has lighter weight primers. Sometimes, (it happened to me,) the heavier milspec firing pins will punch thru the .223 primers and require a shell extractor or potentially worse.
Good luck.....keep us in the loop.
i like eggs.
Fat Possum is offline   Reply With Quote
Old 04-11-2008, 11:02 AM   #79
Skyboi
Skyboi's Avatar
Holy Crap Possum....You know your weapon like I know detailing....freakin Awesome!
This clears up alot of mystery and anxiety I had on mixing uppers and lowers. Great stuff and I will keep you in the loop when I make my buy. Awesome man..
Old 04-11-2008, 06:46 PM   #80
EricCartmann
EricCartmann's Avatar
Send a message via AIM to EricCartmann
AR's are cool like that. They are very simple. You can even change the barrel, and trigger yourself if you have to. They are a great platform and are very reliable. Ergonomics is tops.
2006 CrewCab LE 4x4 Galaxy Black
Born: 12/05
Purchased: 01/19/06.
OEM: BigTow Pkg, OffRoad Pkg, Side Airbag Pkg, Navigation, DVD, MoonRoof, Utilitrack w/ Bed-Ext.
AfterMarket: S50 Sirius Radio, UnderCover Tonneau, UWS Stainless Step Bars, VolantGen3 Intake, PowerAid TBS, Rancho Lift Kit, Helo Maxx6 17x9" Wheels, BFG All Terrains KO's 315/70/17, MagnaFlow Custom Exhaust, Security System: Sig P229 .40 cal
EricCartmann is offline   Reply With Quote
User Name
Password
Bushmaster pocket style fender flares for the Titan? laeger911 Titan Parts & Accessories 1 02-22-2008 05:56 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
