Go Back   Nissan Titan Forum > Titan Discussion > Titan Performance Modifications > IRC VK56 "International Racing Club"
IRC VK56 "International Racing Club" This is a subsection for the IRC VK56.
Old 10-15-2009, 11:34 AM   #1 (permalink)
Cool Headers for titan
I HAVE RECENTLY PURCHASED A 2009 TITAN CREW CAB.IT HAS A NISMO COLD AIR INTAKE,NISMO FULL EXHAUST,HYPERTEC PROGRAMMER.THE PROBLEM I HAVE IS THAT THE NEW SET OF NISMO HEADERS KEEPS SETTING THE CHECK ENGINE LIGHT.I WAS TOLD IT WAS BECAUSE THE 02 SENSORS ARE READING AT THE SAME TIME.NEED TO FIND OUT TO PREVENT THIS FROM HAPPENING.THANKS
MIGHTYMOUSE is offline   Reply With Quote
Old 10-15-2009, 12:50 PM   #2 (permalink)
layer1's Avatar
Re: Headers for titan
First of all, take off the caps keys as you are yelling.
Search is your friend.
So, you are saying you have Nismo Long Tube headers? IF so, you could be running really lean and not getting everything out of your mods. Get rid of the Hypertech and get Uprev.
The problem is that your o2 sensors are in front of you secondary set of CATs. With longtube headers the first set of CATs are removed and now your o2 sensors are reading incorrectly. You will have to extend your o2 sensors behind your secondary CATs. And in order to do so you will need to get new CATs with the pung on the back side.
1/4 Mile in 14.89sec | 90.43mph @ 5900pnds
AKA: ScotchWhore
layer1 is offline   Reply With Quote
Old 10-15-2009, 01:42 PM   #3 (permalink)
O-FiveCC's Avatar
You could have a muffler shop weld in some 02 bungs behind your rear cats instead of buying new ones. But what layer1 said was correct. If you are installing LT headers, you are getting rid of the set of cats that the 02 sensors are reading. Now the 02 sensors are reading uncleaned air straight out of the engine instead of "cleaned air" that has passed through cats. If you look under your truck, look at you cats, then look a little bit in front of them will be some sensors screwed into the pipes (b-pipes)...those need to be moved behind the cats. Although you don't need HF cats to fix the problem, I would recommend them so you can get more performance and a higher quality cat. Also, yes Uprev is a very good idea
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.842 at 96.98--8.78 at 77.75 1/8th 1.92 60' NA FST (pre-PGM)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA cat-back, Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's
NY-Trex wet kit, TransGo shift kit
O-FiveCC is offline   Reply With Quote
The Following User Says Thank You to O-FiveCC For This Useful Post:
layer1 (10-15-2009)
Old 10-16-2009, 08:45 AM   #4 (permalink)
Cool Re: Headers for titan
Thanks for the information.Sorry about leaving the caps on.I think i am going to see about getting 02's moved behind the cats.Is the UpRev a programmer similar set up a the Hyper Tec in set up?
Old 10-16-2009, 08:57 PM   #5 (permalink)
O-FiveCC's Avatar
No Uprev is custom tuning, the hypertech, BD, and SC are handhelds with set tunes that everyone gets. With Uprev you can get your Air/Fuel ratio (AFR) adjusted to its maximum power producing potential while also keeping your engine from running lean whish is not healthy for the motor. Your AFR can change faily dractically running headers,a nd its good to get custom tuned for them.
2005 XE Crew Cab
Old 10-16-2009, 09:22 PM   #6 (permalink)
soljaslimm's Avatar
hey, mightymouse if you dou decide to go with the uprev mod, let me know if your interested in selling your hypertech.
soljaslimm is offline   Reply With Quote
Old 10-17-2009, 07:36 AM   #7 (permalink)
TitanBlue's Avatar
Go to UpRev - Engine Management and look at Osiris Standard software. Prices were just lowered. Everything UpRev does, is through a USB to OBDII Cable and using a Laptop to run the software to flash the truck. They can supply a base tune for you, based on current mods. You can run some 0-60 mph runs and log your trucks performance with the Cipher software that is included in the Osiris purchase. They will look at those logs, and customize your tune for you to reflash. Consequently, it works far better than the hand helds ever could. It is much more sophisticated. You can also have up to 5 different tunes loaded in your trucks memory at once, and simply select which one you want, by using the cruise controls. You do not lose cruise functions, nor need the laptop with you. It appears you like performance, so you will like Uprev!
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 10-17-2009, 09:38 PM   #8 (permalink)
Ryno87's Avatar
Dang how did a 09 get the nismo lt's? :-(
05 CC silver SE pkg.
Performance:AEM CAI,Helix TBS,JBA catback,Nismo LT's,UPREV
Exterior:Smoke Altezza taillights,smoke 3rd brakelight,Full billet grille,20% tint.
Interior:Avic-D3 DD unit,2xKicker CVR comp 10" 1350 planet audio amp,XM,Handsfree BT
Wish List:UpRev,Detroit tru-track,JWT cams,IPT valvebody upgrade,Mr.shift overhaul,Lambo doors,24"rims,07 intake,90mm TB,Autostart
Vice Prez
Ryno87 is offline   Reply With Quote
Old 10-17-2009, 10:27 PM   #9 (permalink)
get uprev and ditch the programmer ASAP!!!!
bj2007 is offline   Reply With Quote
Old 10-19-2009, 09:39 AM   #10 (permalink)
The hole thing started with this 09 as a sales managers dimo and he is a performance junkey.The sales manager is a good friend.The Nissan dealership was getting ready to change hands and the truck had to go or all the performance equipment and leveling kit was going to have to come off.He made me a deal i could not walk away from.I had a 05 before the 09.This bad boy has black metalic paint,nav system,leather,factory wheels painted black to match the truck.***** to keep clean but sweet ride.
Old 10-28-2009, 03:29 PM   #11 (permalink)
SATXTITAN's Avatar
How about some pics buddy..?
<a href=http://img21.imageshack.us/i/cimg2780b.jpg/ target=_blank><img src=http://img21.imageshack.us/img21/4859/cimg2780b.th.jpg border=0 alt= /></a>
SATXTITAN is offline   Reply With Quote
Old 11-11-2009, 11:21 PM   #12 (permalink)
El Mamito USMC's Avatar
ok so the uprev is a reflash to the ecu? but for a mostly stock engine is not worth it. migth as well install a APEX NEO.
El Mamito USMC is offline   Reply With Quote
Old 11-12-2009, 12:39 AM   #13 (permalink)
Fox Delta's Avatar
uhhh no - you log data from your engine, send that data to UPRev and they adjust the parameters for your vehicle based only on the exact data from your vehicle.
Not some "generic" tune that works for all...
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 11-19-2009, 07:12 PM   #14 (permalink)
or if you want to save the whole getting a cat thing, go to your local auto parts store and get spark-plug anti foulers that are threaded for your o2 bung. get two for each o2 sensor. install them into the o2 bungs and then screw in your o2 sensors. its worked for me everytime.
Ctown2Ctown is offline   Reply With Quote
headers for 2005 titan tfritzapexntnet Titan Performance Modifications 28 01-16-2007 08:02 PM
Headers for Titan buzzkillwill Titan Performance Modifications 2 05-23-2005 12:01 PM
Nissian Titan Headers treeeleaf Titan Parts & Accessories 2 02-17-2005 07:56 AM
Titan Headers treeeleaf Titan General Discussion 4 02-14-2005 05:15 PM
Headers for the Titan Cloud 9 Motorsports Titan Performance Modifications 0 03-11-2004 10:24 PM
