I think its 15" 12.5 wide. What do you mean not enough clearance
I have a 2" level. About to add another 2" to the front and rear.
Also think im ganna ad 1.25" or 1.50" adapter on the wheels.
Sent From DroidX Using Awesomeness
A 15" wheel will get hung up on your brake calipers if it would even go on at all. A 17" wheel is the smallest you can run and some of them require grinding some material off the caliper to clear.
It is Impossible to run anything smaller than a 17' rim. And those are certain years of titans(04-07). 08+ smallest running wheel has to be a 18' rim. If it was that easy to run 15's mike I'd have 37's on 15's by now son. Lol. And the tires would cost next to nothing to accommodate that.
Sent from my iPhone 4.7 using El Autoguide.
2008 BLIZZARD CC LE LWB
Flow Monster X pipe/Dual DynomAX bullets dumped w/ DC Sports 4" resonated exhaust tips..!!
PRO COMP 2'' POLY LEVEL KIT..PINCH WELD MOD 8K Xentec HID LOWS/FOGS CST 4'' LIFT SPINDLES/BIlstein 5125 rear shocks
35" Nitto Trail Grapps
Maxtrac 3" rear blocks
Saw 2.5 Race Runner Coilovers
On another note whos T is this? Got a obx sticker on back. Here in Moore. There's all kinda of titans out right now on 19th st. Just saw a blizzard white Titan lowered with double scoop hood kinda looks like 08blizZ! Is that guy still around??
Thats what I thought glad someone else can back up the info too.
Man that's wack as ****. I swear iv seen smaller tires on prerunners
The only way I could see that happening is if they run smaller brake rotors or something. The brake rotor size is what causes the need to run bigger wheels.
You are correcto señor!
The Following User Says Thank You to TURNandBurn For This Useful Post:
It probably was 08blizz. He doesn't come on here much anymore though.
Any of you guys drive a black Pro-4X with XD rims on it? It had a pro-comp sticker on the back window. If so, I saw you going to Chedders on 29th today.
Nice looking truck!
Why is there never enough time to do it right the first time,
But always enough time to do it again?
