Go Back   Nissan Titan Forum > Regional Forums > North East Forum
Old 02-14-2005, 08:31 PM   #1 (permalink)
AJCanon's Avatar
Tow Hitch Question
Anyone have thoughts/advice on where best to have my tow hitch needs addressed? I have been told to just go to UHaul but for some reason I am skeptical...
Just bought my SE King Offroad....best vehicle I have ever owned....I am in Maine and the Titan is loving all the snow in the mountains....
AJCanon is offline   Reply With Quote
Old 02-14-2005, 09:04 PM   #2 (permalink)
JaxTitan's Avatar
Send a message via MSN to JaxTitan
Go to the dealer. The OE Hitch is about $225.00. The key is that comes with 2 relays for your tow harness. These relays if purchased separtely could be upto $80 bucks. It takes about 15-20 mins to bolt on. Plus it will look better......
2004 LE CrewCab 4x2
Dunder Chrome Grille
2" PRG Leveling Kit
20" Boss 309's w/ Goodyear Eagle LS's 275 55 20
Borla XS exhaust with Dual 3 1/2 Chrome Tips
Hood Engine Decals
JaxTitan is offline   Reply With Quote
Old 02-14-2005, 10:34 PM   #3 (permalink)
i have a uhaul hitch on my tacoma. looks good and works great... but the harness is where they get you. If I did it again, I'd definitely go OEM.
Old 02-15-2005, 06:38 AM   #4 (permalink)
I bought a valley hitch $135.00 and I bought the unversal plug at O'reilly's for $12.95 (circular to 4 pin) took me 3 minutes to put them on (air tools)
05 Titan Smoke CC SE
00 RM 250-4 sale
02 CBR 954 RR
74 Harley Super glide
90 CB-1 race prepped (classic) highly modified
06 Gixxer 1k (coming soon)
My drinking friends have a racing problem!
It's ALL about the RIDE!
MOTO-MAX-TITAN is offline   Reply With Quote
Old 02-15-2005, 08:15 AM   #5 (permalink)
Sammy Sandbag's Avatar
http://www.hitchmart.com/$spindb.que...itchview.70530
I've got the Hidden Hitch, I prefered the look over the oem square tube. BTW, the 2 relays that come with Nissan hitch are for electric trailor brakes, not lights. The SE and LE are already wired for lights, all you need is the plug ($12).
-Counsel Yourself
Old 02-25-2005, 12:24 PM   #6 (permalink)
Sammy, Did you also get the T connector for trailer running lights like the website suggests? Since my Titan is pre-wired is that something I would need?
Brianyzf is offline   Reply With Quote
Old 02-25-2005, 01:18 PM   #7 (permalink)
No, I just got a plug adapter from the dealership, but I've been told that late model GM trucks use the same plug as well.
Read this topic for more info: Hitch
Here's a picture of the adapter with the Nissan part number:
Old 02-25-2005, 01:27 PM   #8 (permalink)
rarjar's Avatar
I bought a 7 to 4 flat connector like the one Sammy shows(for trailers w/o brakes), and a 7 to 5 round connector (for trailers w/ brakes), both from AutoZone in the price range of $10-12 each. These adapters cover the waterfront for me.
2004 Titan 4x4 Pearl White LE King Cab
Tekonsha Voyager Trailer Brake Controller
OEM Bed Divider
Superior leaf spring helpers
Lund X-terminator bug shield
Graphite/Titanium leather seats
Born-on date 6/10/04
Purchased 6/19/04
"We're all here because we're not all there!"
rarjar is offline   Reply With Quote
Old 02-25-2005, 01:38 PM   #9 (permalink)
tagjet's Avatar
Trailer Plug
I used the one from my 98 dodge and cannot get the light to come on. Do you know if the Nissan is wired different ground..(float type)
tagjet is offline   Reply With Quote
Old 02-25-2005, 01:39 PM   #10 (permalink)
One relay is for running lights, the other is for the brakes. Your brake and turn signals will work without the relay but your running lights will not work unless your have the relay.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 02-25-2005, 01:40 PM   #11 (permalink)
That I couldn't say for certain. I do know there was another TitanTalk member who used a late model GM oem to 7pin adapter that worked fine. Otherwise the Nissan adapter is your other choice, and it's only $12.
Old 02-25-2005, 02:00 PM   #12 (permalink)
rarjar's Avatar
Tagjet, I believe all of the 7 pin to 4 pin flat adapters are the same (except some have the middle ground pin, which the 4 pin flat connector doesn't use). Theoretically, the adapter should work. I would do the following in sequential order until they work: 1) check the 4 pin trailer connector output using a test light or VOM (using the tail lights and turn signals, this will also tell you which pin is which); 2) check to make sure your trailer is grounded through the trailer electrical plug (don't assume because the trailer is hooked up to the ball hitch that you have a good ground); 3) check the installation of the bulbs to make sure they are making good contact and are all good bulbs; and 4) check trailer wiring by using a test light or VOM at the tail lights. Good luck!
OEM Bed Divider
Purchased 6/19/04
Old 02-25-2005, 02:29 PM   #13 (permalink)
Try your turn signals. If they work then you need the relay or if you have the relay then you might have a bad fuse.
Old 02-27-2005, 11:55 AM   #14 (permalink)
tagjet's Avatar
adapter
I plug the same connector to my other vehicle which has a 4pin connector with no problem. When I use the adapter on my Titan nothing works..
Old 03-04-2005, 08:04 PM   #15 (permalink)
i bought a uhaul hitch and put on my Titan and it looks great.when i bought my 4 flat wiring kit from autozone and put it on i had turn signals and brake lights but no running lights.I then went to nissan and bought a relay switch plugged it in and wham bam it works great now.what im wondering is if i bought the other relay switch for the brakes and bought a different wiring harness the has the 7 round plug and tried using it on a trailer that has brakes.can i use the brakes on the trailer then without having to buy a trailer brake box and mounting it in my truck??????????????
inyourneck99 is offline   Reply With Quote
