Sold my T :( need help with a diesel for new work please - Nissan Titan Forum
Go Back   Nissan Titan Forum > Off-Topic Area > Off-Topic Discussion
Off-Topic Discussion Discussion of Off-Topic items.
Old 03-16-2012, 10:33 AM   #1 (permalink)
natedog's Avatar
iTrader Score: 0 reviews
yea it sucks i am still mourning., but i need a 1 ton dually for a hot shotting business im doing with a buddy. i know some on here know more about the cummins and the 7.3l international motors which i am looking for. i have found 03-06 cummins and 99-03 7.3L fords but not sure about the little things i should look for before i bring my mechanic, i would like to be able to spot any trouble myself. more than likely looking for a 6spd manny but if i spot a clean auto i would consider it too. seems like the front ends on the heavy duty trucks need more servicing than 1/2 tons because of hauling loads, are there any signs besides play in the steering that i should look for? thanks guys i will miss my T fo sho and i still might look for a new later
SOLD, but not forgotten
2004 SE Offroad Crew Cab
33x12.50r17 Cooper St
jba headers
3" i/o bullet
2.5" flowmaster Y
2" level
natedog is offline   Reply With Quote
Advertisement
Old 03-16-2012, 04:42 PM   #2 (permalink)
Shane06fl's Avatar
iTrader Score: 1 reviews
Re: Sold my T :( need help with a diesel for new work please
Both those trucks share darn near the same issues and those are some of the best Diesels sill on the road.
Front brakes (caliper and rotors suck)
Front end death wobble. Dodge is more prone but Ford is where there with them
Transmissions are the weak link in the drive train
Both engines have fuel weak fuels system
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
The Following User Says Thank You to Shane06fl For This Useful Post:
natedog (03-17-2012)
Old 03-16-2012, 06:49 PM   #3 (permalink)
Banned
iTrader Score: 3 reviews
Dodge has the weakest front suspension setup of all the big 3 diesel trucks. Their 3/4 ton shares components with the half ton and their 1 ton isn't much better. The Cummins and 7.3 Powerstroke are stump pullers both, but I'd go with the Ford SD for the stronger chassis. If I were gonna get any diesel rig used, I'd have a 06-07 LBZ Dirty Max with the A1500 6spd on my short list of possibles.
Toughtitan08 is offline   Reply With Quote
The Following User Says Thank You to Toughtitan08 For This Useful Post:
GMVisitor (03-16-2012)
Old 03-16-2012, 07:37 PM   #4 (permalink)
xxtitanxx's Avatar
I'd get a duramax, my dad has an 03 and an 11. 03 is all work truck bought it new and it's still going strong.
xxtitanxx is offline   Reply With Quote
The Following User Says Thank You to xxtitanxx For This Useful Post:
Old 03-16-2012, 07:58 PM   #5 (permalink)
NBhunter80's Avatar
Go with the Ford 7.3L PSD. If you can find an '03 with a 7.3L, that would be your best bet. That was the last year they made the 7.3L, and the first year they made FX4 package. The cummins is a great motor, but as was mentioned, I would go with the Ford because IMO it is a better truck overall, and they look tougher. I had a 6.0L PSD before the Titan, and although I had the classic 6.0L issues (head studs and cracked egr cooler), the truck overall was great. The 7.3 is pretty much bulletproof. I had issues with steering parts and front brake calipers and hubs, so look at those before you buy. I ended up installing some steering stabilizers to get rid of the death wobble, and some warn manual lockers when my locking hubs took a crap. Both were pretty cheap and easy fixes. Good luck!
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33x12.50r17LT Hercules Trail Digger tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, Hawk LTS brake pads, MOOG lower ball joints, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is online now   Reply With Quote
The Following User Says Thank You to NBhunter80 For This Useful Post:
Old 03-16-2012, 08:20 PM   #6 (permalink)
sboyd18's Avatar
Both engines have fuel systems
Don't most trucks have fuel systems?
sboyd18 is offline   Reply With Quote
The Following User Says Thank You to sboyd18 For This Useful Post:
Ghostfire (03-17-2012)
Old 03-16-2012, 10:16 PM   #7 (permalink)
After driving both you are referring I would go with a 03-07 5.9 cummins. They get a few mpg better under load with a manual. Both trucks the trans is the weak link and the engine will last longer then the body.
greytitan is offline   Reply With Quote
The Following User Says Thank You to greytitan For This Useful Post:
Old 03-17-2012, 08:17 AM   #8 (permalink)
iTrader Score: 2 reviews
I vote for the cummins. I agree with the comments above about the issues the dodges have, but you cannot beat the cummins in the diesel world. That inline motor is built to work. I had a 04.5 cummins for a few years and it was an awesome truck. If you do go with the dodge, remember the 03-04.5 are slightly different than the 04.5 through 07. The 03 and early 04 trucks have slightly less power, a terrible frame mounted fuel system (which should be replaced, imo), no cat converter and usually get slightly better mpg than the later ones. I loved my dodge and wish I still had it. Ill even throw in a few pics to help ya make your decision.
Sittin a little low in this one. Left the scale with just over 4k of fill dirt in the bed.
Stovetop5535 is offline   Reply With Quote
Old 03-17-2012, 04:00 PM   #9 (permalink)
Shane06fl's Avatar
Yes they do but I figured another smart azz would fill in the blanks
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 03-17-2012, 05:27 PM   #10 (permalink)
NBhunter80's Avatar
Well I better add a few of my old truck to make things even
Old 03-18-2012, 11:20 AM   #11 (permalink)
natedog's Avatar
havnt really found anything i like yet, might be leaning towards a srw truck as i might not be towing as much weight as i initially thought. i think im leaning to the cummins.
jba headers
3" i/o bullet
2.5" flowmaster Y
2" level
Old 03-18-2012, 04:46 PM   #12 (permalink)
Banned
Just better hope the previous owner took care of the front end on it. Wheel bearings, hub assemblies, control arms, all weak points on the Dodge. The Ford SD has monstrous control arms that look like a damn dinosaur bone. The 6.0L is a good engine too once you get around the head bolt issues and have good injectors in it.
Old 03-18-2012, 05:10 PM   #13 (permalink)
lookzcustoms's Avatar
heres some links from one of the best diesel magazines out there in my opinion
Best Diesel | Find Information on Best Diesel at Diesel Power Magazine
The Cheapest Diesels We'll Ever Love - Diesel Power Magazine
Eight Failures Of Diesel Engines - Diesel Power Magazine
2006 titan CC offroad, Injen intake, nismojunky grounding kit, bully dog gt @ WOT performance, 5100 bilstein, blacked out rims
lookzcustoms is offline   Reply With Quote
Old 03-18-2012, 06:06 PM   #14 (permalink)
vilim12's Avatar
Some go at 90k and some go at 300k. Ours took a dump at 96k and my friends took one at 230k and he was bullydogg tuned since brand new. Go figure right?
2008 Nissan Titan Pro-4x CC LWB Smoke
UNDER CONSTRUCTION
vilim12 is offline   Reply With Quote
Old 03-18-2012, 06:39 PM   #15 (permalink)
Banned
Yeah you never know. I know the 5R110 is a stout transmission. You know what I am talking about with the control arms right? They're huuuge!! I have a co-worker who bought a low mileage Ram Cummins 3/4 ton and had the wheel hub nearly shear off within 60k miles. Cost him $295 to get the part.
Advertisement
sold the T..:-( TitanOn40's Buy/Sell 10 11-06-2011 06:34 PM
Sold the T.....:( chieflikalotapus Titan General Discussion 49 02-08-2011 06:04 PM
Sold!!! garcia1989 Buy/Sell 92 08-24-2010 08:57 PM
Beat a F250 Turbo Diesel on the way to work this morning jamcguire12 War Stories 9 11-27-2006 04:08 PM
SEO by vBSEO 3.3.2
