My fiancee and I have a 10 gallon tank with a dinosaur bichir(Senegal bichir) and a plecostomus. We have been wanting a bigger tank but don't want to do a salt water tank yet.
We just bought a 75gal tank with the build in filter system. We are setting it up right now and thinking about making it an African Cichlid tank.
If you have a tank post up some pics and specs on it.
Also, if you have any tips for me running that 75gal tank, please share!
My brother-in-law has a 90gal saltwater tank and he is obsessed. Needless to say he got a killer deal on it and it has turned it his number one hobby, its pretty bada$$! From talking with him, you need alot of room and need to know about a little bit of science because of the water but im sure its something your local saltwater fish tank people can tell you.....Ill get you some pics of it soon.
__________________ 2011 PRO-4x----> ALL STOCK!!!
"What we do in life, Echoes in eternity...."
My wife and I used to have a 75 gal freshwater tank. We initially had a pair of Oscars in there, and man are those things messy. Even with two Magnum canister filters it was still a weekly task to clean them. We eventually turned it into a Leopard Gecko terrarium before selling it.
I would recommend only an inch or so of substrate, more than that and you are just asking for stuff to get built up in it. If you are doing African cichlids remember they like alkaline water which usually requires some rocks or woods to help regulate the pH.
It's also a good idea, for a tank that size, to let it cycle for at least a week before adding any fish. Check the levels daily and make sure things look alright. Once the levels have stabilized for a few days, then slowly add a couple fish. Even a couple small fish in a large tank can change the levels.
Good luck with your 75 and be sure to post some pictures after you get it up and running.
I had a 125 gallon tank with 6 red bellys. Got them when they were the size of a quarter and almost see thru. 2 years later they were 10+ inches long. They could easily eat 200 feeder comets a week.
My suggestion is dont use any under gravel filters, they trap more debris than they clean. Get a python siphon cleaner, it really helps in vacuuming and water exchanges in larger tanks. It sounds like you have built in skimmer boxes on the 75. Personally I like to use an oversized wet/dry filter. They are mostly used in saltwater tanks, but I use them in freshwater tanks as they filter so well and filtration rates don't drop like canister filters when they get clogged up with waste.
On a larger tank, cycle the new water for a couple weeks to help build up the biological filtering, you can buy a bacteria pack to speed things up. Add some cheap feeder fish the second week to help boost the bio filtering even more. When the cloudiness disappears, add your better fish.
Its similar to your 10 gal, just more chemicals and more to clean.
2011 - SV HM CC SWB
Airaid MXP and BDGT
Retired - 08.5 XE CC SWB (factory freak)
14.8 in 1/4 No mods
14.4 in 1/4 (50 shot, untuned)
14.1 in 1/4 (75 shot untuned and 4wd)
13.9 1/4-mile (100 shot)
Injen, Transgo, Nitrous Express, Zex, Nos and Uprev.
Without fish, there is nothing to cycle. If you have chlorinated water, use a dechlorinator. You probably already know that. Not a bad idea to take a sample of the water you intend to use to fish store to see if the pH hardness etc will work for the fish you plan on keeping.
__________________ - 2004 Galaxy Black KC OR 4x4 -
Buy a good test kit for the water, I always use a handful of feeder goldfish to cycle my tanks. It could take up to 8 weeks depending on the water you use to fill it. If you are using your tap water test it. That way you know where your water is to begin with. I have a 45 gallon mixed African cichlids tank and soon as it cycles a 55 gallon jack dempsy cichlid tank. If you let the tank cycle with some cheap fish it will save you a lot of frustration. Oh yeah, cichlids and plants don't go well together. They chew and dig them up.
PA CHAPTER
2008 Galaxy Black CC Pro4X
Weather Tech in channel vent visors, Tinted front windows,
Grillcraft Black MX series Grill, ArmaDen Led's every where, Armaden Hid's, VHT Tails, DIY wheels, DIY black chrome emblems, Axle vent mod, S&B cold air intake, TBS screen removed, Magnaflow cat-back, Magnaflow X-pipe, Magnaflow cats, Custom B pipes, Bilstien 5100's, Cooper ST Maxx
Obx Longtubes and Uprev
The Following User Says Thank You to allbtitan For This Useful Post:
Do a fast cycle, throw a few fish in there, wait a day go to a local pet store and ask for a handful of gravel from the bottom of a well established tank. Stick that in the bottom of your filter, Done. Been doing this for 10+years
I have a 50 gal freshwater tank with three black moors and six white clouds, I run a bare bottom tank. I used a product called StartSmart made by TLC, cycled the tank almost instantly.
2006 2WD XE Smoke CC
-Preferred Package
-Rhino Liner
-MagnaFlow Muffler
-Vibrant Ultra Quiet
-302/45/22 Fulken Ziex S/TZ04
-Kenwood DNX6980 w/Kicker KS 6x9 and 6.5
-ScanGauge II Dash Mounted
