Tried replacing my rear tranny mount yesterday, those friggin' crossmember bolts ain't coming out. 18" breaker bar was no help. So I got to thinking, why not get an electric impact? I don't want to go air, don't have the room for a compressor. Can anyone recommend a good electric impact? I like these two, DeWalt and Milwaukee.
Sorry but unless that electric impact can do 600 ft lbs for the big stuff, you wont get anywhere.. I have not seen an electric impact that does more than 200/300
__________________ 04 KC Smoke Titan 4X4 PRG, Hypertech, 08 Brake Upgrade, Black Rhino 18x9 +12, 305/65/18, Bilstein 5100's, Pro4x Springs, AAL's, CSF Rad, 2º Advance, Debadged, GoGrounding, Radiator Bypass Cooler, AIRaid MXP Intake, Axle Vent Mod, DDM 5k Lows & 3k Fogs, Blacked out Head lights, Stillen LT, BALLER PRT PIPES (BECAUSE I DONT LIKE BUYING SHIET TWICE), JBA Exhaust, Magnaflow Glasspack, Vibrant, Tech12, Volant LED Tails..
If you want an electric impact (which have less than half the torque of a good pneumatic unless you spend a lot for a Snap On) why not get a cordless electric, which have just as much torque as corded electric impacts? Cordless cost more with batteries and charger, but are in the same ballpark if you already have batteries and charger and can buy just the bare tool. I just bought a high torque cordless Makita impact for $159 shipped because I already have lithium Makita batteries and charger. A guy recommended the Makita in another thread. I am not keen on having the disadvantage of being tethered just like a pneumatic, but only having half as much torque.
I've grown up with DeWalt battery powered tools, and hated them. The older 18v and 14.4v tools were nearly useless after about 5 minutes of use.
But on the other hand, my corded DeWalt drill and angle grinder kick azz. Never ran into anything they couldn't handle.
But now that AJ had me looking back at pneumatics, the choices open up a lot... So does the opportunity to pick up a sprayer. I'd love to get into that, and stop using spray paint. Lol
I ended up buying the same Dewalt as in your first post. But mine was the detent pin model instead of the hog ring.
I haven't yet had a chance to use it for anything other than changing tires. It doesn't spin them off instantly like you see in Nascar, but after about 3 seconds of letting it hammer away, they come off.
If you haven't already bought one before I get a chance to try it on some seized bolts, I'll post with a report on how it does.
iTrader Score: 0 reviews
Re: Electric Impact advice
I have both electric and air impact. They both do what I ask of them.
I have used the electric on tires and did NOT have to wait to remove or install the lugs nuts. They spun just fine. I have also used the electric to work on the tractor and it worked just fine.
I have used the air to remove some things the electric would not remove and have also used the electric to remove things the air would not. Sometimes I think it has more to do with the way the impact hits then the foot pounds. The electric impact is heavier by nature then the air and therefore seems to deliver more impact to the driver and not the hands holding onto the tool (just an observation)
I think either way you go you will find a tool that works.
BTW - my electric impact is a Harbor Freight tool. I have had it for about 8 years and it still works just fine.
You could pick up an electric from HF and see if it will remove what you need. If it does not, return it - they are really good about taking things back.
2007 XE CC Silver
202,000+ miles
Stock Intake - Stock Exhaust - Receiver Hitch - Original Spare
Wrangler 245/75 R17 Load Range E Tires
New set of plugs changed at 125,603 miles (hope my mpg is back up)
Factory recalled fuel sender replaced (by Nissan of course)
Single Din Kenwood radio with storage space below
Garmin Nuvi 205W
Prodigy P3 Electric Brake Controller
Cabin A/C Filter (yes I use them and keep them maintained - living in Florida, I need my A/C to keep working NAPA #FIL 4854)
Homemade wooden tool box in the back of the bed and a Kobalt Diamond plate box in the front of the bed
Dented Bed on passenger side
It's a work truck - I had no additional MODS planned - but due to the dent, I am thinking of changing to a flatbed
The Following User Says Thank You to qapla For This Useful Post:
