Got woke up this morning by what sounded like someone rolling a metal wheeled wagon across my roof. Went to the front door to look out the tall narrow pane of class beside the door. It is covered on the outside with a thick sheet of plexiglass. That area, the front door itself (steel door), and the garage door (metal with reinforcement braces) are the only areas without metal hurricane shutters attached to them. That is also where the winds and rain are coming from at this time.
We are getting intermitant bands every so often and they are getting stronger each time. There has been about 15 min to 30 min between each one. But the gap between is getting shorter.
I could not see my neighbors house across the street it was raining so hard. The front door is braced now with a special brace that fits under the door knob and goes down at an angle to the floor where the rubber feet of it prop/force it against the door preventing it from opening even if the door was unlocked. I put this on this morning because the door was moving slightly inward with the wind pressure. About 60 to 65 mph winds, which is nothing yet. There is also a storm door over the front door with a heavy metal frame and storm windows that slide up and down. We rolled up 3 towels, put them in a garbage bag and duck taped the bag. Then we put that down at the foot of the door, between the 2 doors to prevent water from being driven up under the door. Has never happened with the other canes we have been through, but just getting ready. It has happened to a friend before.
Put a big sheet of plywood across the reinforced garage door, on the inside, and backed the Xterra up to it snug. Put the e-brake on also. Put "C" clamps on 3 areas where the garage door folds normally. There are reinforcement braces all across the door, but I am not gonna wait for problems. Alittle rain was driven between the door sections (thats never happened), but not even enough to make the floor wet. Also backed the lawn tractor up to the door and set its brake and put it reverse.
Moved the Titan to the back side of the house. Had to have the GF hold open the double door gate (wood privacy fence) to drive it in behind the back side of the house. Parked as close to the house as possible. Might or might not help, but the front driveway will have a big palm across it by tonight or tomorrow I'm betting, so she got moved. Will switch sides of the house if possible later when needed.
Flash lights in almost every room. Battery operated gadget with a lantern, flashlight, radio, tv etc.... ready for loss of power. Good amount of batteries for everything.
Am updating post every couple of minutes while typing to get most of it out in case I lose power. So it will look edited every so often.
Getting the dog out inbetween bands to use the bathroom. Can hear my soffeting and trim groaning on the house. Had to go out inbetween the 1st 2 bands and unclog a few areas of drainage I set up for the yard after the 1st cane went through years ago. Helped alot. Had to dig a couple of quick trenches to direct water away from the house and towards the drainage areas I set up to flow towards the street. not really too close but trying to keep it that way. I don't think my efforts will matter when the meat of this thing hits though.
I will probably get roof damage (shingles, trim, soffeting only I hope) some flooding of the lot I'm on, hopefully not the house. Never happened (flooding) before even with all day long FL thunder storms, but this baby is not typical. Hopefully the Titan will be alright, might need her to move to another home if this one gets wasted.
Both cars are pretty much full with gas, and thats good cause FL has almost none right now and won't get any for awhile.
Have a X-Power Pack Plus (power source) that will let us have alittle power if we lose power, basically a big car/truck battery that lets you plug in car accessories and house plug items. But I think we will save it for the fans we have to make sleeping alittle more comfortable, if we lose (probably will happen) power.
Just went outside between to big bands and filmed the wind, houses around mine, stop sign twisting (the intersection street sign on top of it is gone). Stayed in my front entryway, some small debris moving around, not to bad, but don't wanna have to go to the hospital right now for a stupid cut or break or whatever.
Starting to lose power alittle.
Back on now, flickerd a few times. Got the tub full of water, and a bucket, to use in the toilet if we lose water pressure. Parents said you can fill up the tank and the bowel with the bucket and gravity will do the rest. I hope so.
The brunt of this will hit after dark (@#&*), they always seem to. Crap, I hate that. We lucked out and found a open resteraunt last night and got a great big pizza pie and a couple of cold pitchers, never tasted so good. Might be my last warm meal and cold beer for awhile.
Gonna get off now and set up our panic room. Basically the master bedroom walkin closet on the more sheltered side of the house. Gonna get the 2 cats in their car carriers and the dog in his harness. Gonna put up a sheet of plywood over us, Lean-2 style supported by a huge solid old dresser just in case the roof caves in...off...whatever. Will have battery TV, radio, water, flashlight, cell phone ready to go. Wish us luck.
Don't think I will be going outside again. Can you believe there are actually people driving around sight seeing and taking a walk with rain suits on. Hope they don't catch that street intersection sign. It's like a big metal plus sign.
Disclaimer........................................ ........................................... (Directed to my new special friend). I do not think, wish, want or mean to imply, in anyway, that I am a "Hurricane Hunter" or meteorologist because I am talking about a hurricane.
Note: not gonna even try to go read the Overtime thread to see what is there. Don't need that garbage right now.
