Go Back   Nissan Titan Forum > Off-Topic Area > Off-Topic Discussion
Off-Topic Discussion Discussion of Off-Topic items.
Old 08-11-2006, 10:04 AM   #1 (permalink)
? on tire sizes...
I never did get the hang of that formula thing, but I imagine one of you is crafty with it...
What's the difference(Height and Width) between:
285/70r16
275/60r16
Blackin is offline   Reply With Quote
Old 08-11-2006, 11:30 AM   #2 (permalink)
stlblues's Avatar
Re: ? on tire sizes...
285 will of course be taller, not sure exactly how much but not a huge difference. the 60 will be about an inch wider than the 70. Don't have the exact formula on had. Just slap on some 305/70/20s.
Give BLOOD play HOCKEY-04 Titan SE CC Off-Road-05 Honda Odyssey EX-L Res
-89 Honda PC800-99 Suzuki 500 Quadrunner
stlblues is offline   Reply With Quote
Old 08-11-2006, 12:45 PM   #3 (permalink)
The first number is the width
The second is the height
The third is the rim size
titanQ is offline   Reply With Quote
Old 08-11-2006, 01:27 PM   #4 (permalink)
d0va's Avatar
285/70r16=31.7" x 11.2"
275/60r16=29" x 10.8"
try this site http://http://www.raingler.com/tech/metricTire.asp
coverts it to metric ez to read
Pm for a Signature Request
Check out my Photoshop Signature Album
d0va is offline   Reply With Quote
Old 08-11-2006, 01:55 PM   #5 (permalink)
gr8titan's Avatar
285/70r16
275/60r16
Formula to get OD (outside diameter) or height of a given tire:
width (mm) x aspect ratio X 2 plus the wheel diameter in inches
23.4
First # is width in mm, 2nd # is profie aspect ratio in percent, 3rd # is wheel diameter in inches
Example on first tire:
1. (width) 285mm multiplied by 0.7 (this is decimal equivalent of 70% profile) equals 199.5mm
2. divide 195.5mm by 23.4 equals 8.52 in. (to convert sidewall thickness from MM to IN.)
3. multiply 8.52 by 2 equals 17.05 in ( to get total sidewall thickness of tire in inches)
4. add 17.05 in to (wheel diameter) 16 in EQUALS 33.05 inches OD
Using this formula, the 2nd tire is only 30.10 inches in diameter which is smaller than the first tire.
Mathematically, 285 tire is only 10mm (or 0.427 inch) wider than 275 tire.
Hope this helps
gr8titan is offline   Reply With Quote
Old 08-11-2006, 02:04 PM   #6 (permalink)
konigfritz's Avatar
Thanks for the formula!!
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
brake sizes eddyeight Titan Wheels, Tires & Brakes 0 06-23-2006 07:25 PM
? about 20" tire sizes jungle jim Titan Parts & Accessories 9 04-05-2006 10:30 AM
CST lift, different wheel/tire sizes? chris415 Titan General Discussion 2 01-25-2006 03:01 PM
Tire sizes HVACman Titan Wheels, Tires & Brakes 8 02-19-2005 07:46 PM
tire sizes? bigd2115 Titan Interior Discussion 5 08-09-2004 07:29 AM
