Go Back   Nissan Titan Forum > Off-Topic Area > Off-Topic Discussion
Off-Topic Discussion Discussion of Off-Topic items.
Old 08-22-2006, 07:58 AM   #1 (permalink)
Question Aftermarket HEI units
I'm looking to replace my stock distributer on my small block Ford and Chevy engines. They're both late 60's vintage. It looks like there are plenty of aftermarket HEI distributers out there. Has anybody done this and if so, are there any drawbacks and what brand would you recommend??
ted hanson is offline   Reply With Quote
Old 08-22-2006, 09:00 AM   #2 (permalink)
konigfritz's Avatar
Re: Aftermarket HEI units
I have, no drawbacks.
#1 Make sure you switch to an alternator that has an integrated voltage regulator. (for GM, not so sure about ford)
#2. Make sure you have really good grounds to the engine and body.
#3 You could convert to a 1 wire altenator, works great less wires.
#4 MSD makes a great unit if you are replacing the whole dist. If not a standard GM hei cap and coil will work fine.
#5 Should use coiled wired spark plug wires, not solid wire
#6 will probably have to change to a spark plug intended for HEI. slightly diff heat range.
Or you can use this http://www.pertronix.com/ignition_products/ignitor.htm
They work well, but I like my HEI better.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 08-22-2006, 11:00 AM   #3 (permalink)
Yellomantis's Avatar
Jacobs has worked for me in the past in my old 69 rs/ss
www.myspace.com/yellomantis
Aftermarket Head Units MileHighTitan Titan Visual & Audio Discussion 3 03-06-2006 06:33 AM
Japanese Head Units ecbmxer Titan Interior Discussion 3 05-18-2005 05:30 AM
Question about mounting 2 single DIN units dram56 Titan Interior Discussion 12 03-29-2005 06:29 PM
140 Fuel Sending Units on Backorder?? BDTITAN Titan General Discussion 5 12-16-2004 09:37 PM
