How do I convert a Bitmap Image to a JPG File? I have tons of pics I would like to post, only problem is that I can't convert them.
Thanks, Brian
If you open it with MS paint, you can choose to save it as anything you want. Try it.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
On, a further note, you can convert any pic to a different format through MS paint. If you want details, I will supply them.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Once I go into paint, what do I do then?
Go into File, Edit? I can't seem to find anything that indicates how to switch...Thanks
Goto file save as, and there will be a title for the file, under that will be a drop down box, to change it's format.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
If you want a decent picture editing software that is free you can look at something called - Gimp.
Ill use paint for some small stuff here and there - changing the size (Ctrl W) or small modifications but for everything else I use Gimp or Picasa. Both Free :-)
I got a 4X4 04 LE Titan CC, BT, Modded RF - TECH12Volt Sub Box with 12" Mephis Woofers, HIfonics Amp 600 RMS, 6" Pro Comp Lift, Nitto Tires, American Racing Mohave Simi Bead Lock Rims, Rad Flo 2.5 front, Bilstein rears, Brute Force AEM CAI, and Banks Exhaust, Stillen VKProModule.
MS Paint, I can remember as a kid thinking how awesome that program was!!! It's good for doing what you said, changing the file type and resizing, there are much better programs out there for sure.
