Originally Posted by helomech
Don't know anything about the mixer, but my hot water heater went out last night. Just got the new one put in. The gut at lowes said a bunch of water heaters went out yesterday, he never sold that many before.
Hmmmm.. sounds like a plumbing conspiracy....
If you have hot water and then lose it quickly, it's most likely your water heater. If you just have some control problems at the shower faucet, but your other faucets in the house are working properly, chances are it's the mixing valve in the faucet. From what I've seen after installing two of the "No-scald" shower nozzles, the mixer is internal and you'll most likely need to replace it. Additionally, the ones I installed had a little tab that you set and fastened in position inside the handle. That set the highest temperature that the faucet would allow after the water is mixed with cold.
Take the cover off the handle and you should see the blue/red slide adjuster. On mine it was fastened with a single screw, but depending on the age of the unit, yours may be different. If adjusting that doesn't help, you may need to replace it.
