Originally Posted by westondean
I don't understand why people can't accept the fact that evolution is basically proven. I mean that by no means denies the existence of God or a creator. Matter and energy is the basis of all life, so why couldn't that be what God originally made, therefore making the world and all of us in one swift move...?... Isn't it possible that all religions are just ways of explaining the unknown in their times and included morals because everyone has a conscious and morals to some point???
If evolution is basically proven then how do you explain the following:
"NOT ONE CHANGE OF SPECIES INTO ANOTHER IS ON RECORD. We cannot
prove that a single species has ever changed."
- Charles Darwin
The human body (or the body of any other creature) cannot live
without most internal organs, such as the heart, the lungs, the liver,
et cetera. Remove any of these organs, and the specimen dies. This
implies that the entire body was created at one point in time.
Natural selection cannot produce new genes; it only selects among
preexisting characteristics.
According to ALL theories on the evolution of the solar system:
a. The planets should all rotate on their axes in the
same direction; Venus and Uranus rotate `backwards`.
b. All 42 moons of the various planets should revolve in
the same direction; at least 11 revolve `backwards`.
c. The orbits of these 42 moons should all lie in the equatorial
plane of the planet they orbit; many, including the earth's moon,
are highly inclined.
Human footprints are found alongside dinosaur footprints in the rock
formations of the Paluxy riverbed in Texas. This obviously shows that
man and dinosaurs lived at the same time and the same place. But
evolutionists claim that dinosaurs became extinct about 30 million years
before `man` supposedly began to `evolve`.
MANY DATING TECHNIQUES SHOW THE EARTH AND SOLAR
SYSTEM TO BE YOUNG
1. Direct measurements of the earth's magnetic field over the past 140
years show a steady and rapid decline in its strength. This decay
pattern is consistent with the theoretical view that there is an
electrical current inside the earth which produces the magnetic field.
If this view is correct, then 25,000 years ago the electrical current
would have been so vast that the earth's structure could not have
survived the heat produced. This would imply that the earth could not be
older than 25,000 years.
2. The atmosphere has less than 40,000 years worth of helium, based on
just the production of helium from the decay of uranium and thorium.
There is no known means by which large amounts of helium can escape from
the atmosphere. The atmosphere appears to be young.
3. The rate at which elements such as copper, gold, tin, lead, silicon,
mercury, uranium and nickel are entering the oceans is very rapid when
compared with the small quantities of these elements already in the
oceans. Therefore, the oceans must be very much younger than a million
years.
4. Evolutionists believe that the continents have existed for at least
1 billion years. However, the continents are being eroded at a rate
that would have leveled them in a relatively short 14 million years.
Since 1836, over one hundred different observers at the Royal
Greenwich Observatory and U.S. Naval Observatory have made direct visual
measurements which show that the diameter of the sun is shrinking at a
rate of about .1% each century or about 5 feet per hour! Furthermore,
records of solar eclipses indicate that this rapid shrinkage has been
going on for at least the past 400 years. Several indirect techniques
also confirm this gravitational collapse, although these inferred
collapse rates are only about 1/7th as much. Using the most
conservative data, one must conclude that had the sun existed one
million years ago, it would have been so large that it would have heated
the earth so much that life could not have survived. Yet, evolutionists
say that a million years ago all the present forms of life were
essentially as they are now, having completed their `evolution` that
began 200 million years ago.
If man and languages `evolved`, the earliest languages should be the
simplest. On the contrary, as one studies languages that are
increasingly ancient, such as Latin (200 B.C.), Greek (800 B.C.), and
Vedic Sanskrit (1500 B.C.), they become INCREASINGLY COMPLEX with
respect to syntax, cases, genders, moods, voices, tenses, and verb
forms. The evidence indicates that languages do not Evolve, they
DEvolve.
Just a few things to think about
