Go Back   Nissan Titan Forum > Off-Topic Area > Off-Topic Discussion
Off-Topic Discussion Discussion of Off-Topic items.
Old 08-21-2008, 09:03 AM   #1 (permalink)
54warrior's Avatar
Brain Teaser
This was sent to me in an email, I think I have the answer.
You can fill the tub from the cold water tap in 6 minutes and 40 seconds, while it takes
exactly 8 minutes to fill it from the hot water tap. After the tub if full, and you pull out the
stopper, it takes the water exactly 13 minutes and 20 seconds to run out. ~
Now, if you leave the stopper out and open both the hot and cold water taps all the way,
how long will it take to fill the tub???????
2005 Nissan Titan CC SE 4x4
Old 08-21-2008, 09:06 AM   #2 (permalink)
Skyboi's Avatar
Re: Brain Teaser
Uhhhhhh......... FOREVER?
'07 Granite SE CC 4X4
Pop Pkg * Tow Pkg
Fogs
Old 08-21-2008, 09:22 AM   #3 (permalink)
54warrior's Avatar
Re: Brain Teaser
Nope, the cold and hot water are filling the tub at a faster speed than the drain is draining it, there is an answer
Old 08-21-2008, 10:05 AM   #4 (permalink)
Quartz's Avatar
Re: Brain Teaser
300 seconds (5 minutes).
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Old 08-21-2008, 10:09 AM   #5 (permalink)
Re: Brain Teaser
i know nothing about the dynamics of hydraulics but a wild azz guess says assuming the flow rate of hot and cold water will offset each other equally when both are turned on, i say it will take approximately 13 minutes 20 seconds to fill it. (13.33/(6.66 + 8)/2) * (6.66 + 8)/2 = 13.33 or 13 minutes 20 seconds.
silver 2004 4x4, CC, LE (non big tow)
bought new in Feb '05
LazerLite tonneau
brake fix done at 22k, no issues since
nicest and most practical vehicle i have ever owned!
kman is offline   Reply With Quote
Old 08-21-2008, 10:12 AM   #6 (permalink)
Send a message via ICQ to PuvMan Send a message via AIM to PuvMan Send a message via MSN to PuvMan Send a message via Yahoo to PuvMan
Re: Brain Teaser
thats what i got
(Rh + Rc - Ro) * t = 1
8Rh = 1
6.66Rc = 1
13.2Ro = 1
Rh = .125
Rc = .15
Ro = .075
(.125 + .15 - .075) * time = 1
1 / .2 = 5
edit: although, a full tub will drain at a faster rate to begin with than a 1/2 full tub due to increased pressure (both with diminishing returns)............. so then we would need to use some crafty calculus to determine the true answer.
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
05 LE Crew Cab 4X4 SMOKE
Off Road, Big Tow, Navi, DVD, XM, Sunroof, Underseat Storage, Bed Divider, Bed Extender
Aftermarket:
Husky Liners, ActiveTuning Grounding Kit, JetTech Spring Helpers (currently removed), Undercover Tonneau, Lund Interceptor, Wade Window Visors, Fram Boost, Bushwacker Fender Flares, CompuStar 2W900FM-AS, 2* Timing Advance, Siemens HKW-700 Bluetooth Car Kit, Two 11.Kv.2s running of an eD NINe.1 in custom BWR boxes coated with bedliner, 4" PRG Perf Package (SAWs, PRG Arms, 1" Deaver Pack, Bilsteins), 20" Axis Titan rims w/ 33" Nitto Terra Grapplers
Coming Soon:
another new rear end.. haha
trutrac
trac bars
power steps
custom 12" fiberglass sub-box (thanks rcantu!)
Exhaust
PuvMan is offline   Reply With Quote
Old 08-21-2008, 10:16 AM   #7 (permalink)
Quartz's Avatar
Re: Brain Teaser
Yea but who wants to do differential calculus for a brain teaser. Not me.
Old 08-21-2008, 10:20 AM   #8 (permalink)
baseballfanz's Avatar
Re: Brain Teaser
What a waste of water.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
Old 08-21-2008, 10:30 AM   #9 (permalink)
Juday's Avatar
Re: Brain Teaser
13 minutes 20 sec....give or take a few....
35x12.5x17 Cooper Discoverer STTs
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
PowerSlot Cryo Rotors w/ Hawk LTS pads from Frozen Rotors
Superchips Cortex
Old 08-21-2008, 10:49 AM   #10 (permalink)
Re: Brain Teaser
The World's Biggest Puzzle Book - Google Book Search
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
Aftermarket:
Coming Soon:
trutrac
trac bars
power steps
Exhaust
Old 08-21-2008, 10:50 AM   #11 (permalink)
Re: Brain Teaser
oh yeah i see how my calc is way wrong. You guys (quartz and puvman) are you assuming there is both a hot and cold water spout flowing into the tub separately, otherwise if it was a typical setup flowing into one spout would that not cause a capacity contraint when both hot and cold are turned on? What would your answer be if one spout? 7.69 minutes?
LazerLite tonneau
Old 08-22-2008, 08:20 AM   #12 (permalink)
Juday's Avatar
Re: Brain Teaser
So what's the freakin' answer already? I know I got it wrong, but I'm curious for the answer and how it's solved.
AEM Brute Force CAI
2* Timing Advance
Superchips Cortex
Old 08-22-2008, 09:27 AM   #13 (permalink)
Quartz's Avatar
Re: Brain Teaser
The answer is 5 minutes.
There are many ways of figuring this out but here's how I did it. To make the math easier I assumed a tub that holds 100 gallons
Divide 100 by the time (in seconds) that it takes to fill with cold water. Repeat this for the hot water. Add these two numbers together and you will get the rate at which the tub will fill up in gals per second.
Now divide 100 by the time it takes to empty the tub. This will give you the rate that the tub empties at in gals per second.
Subtract the rate the tub empties from the rate the tub fills and you get your actual fill rate.
Now divide 100 by the actual fill rate and you get the answer in seconds.
I hope this helps.
Old 08-22-2008, 11:52 AM   #14 (permalink)
Re: Brain Teaser
I hope this helps.
your assuming hot and cold are coming out of separate spouts right?
LazerLite tonneau
Old 08-22-2008, 11:55 AM   #15 (permalink)
Quartz's Avatar
Re: Brain Teaser
Yes I did.
Your brain age. BBtruck Off-Topic Discussion 30 08-06-2008 08:43 PM
Brain freeze, need help..... CoachBoone Titan General Discussion 3 12-28-2007 09:52 AM
Ouch my brain nadjartodd Titan Engine, Transmission & Drivetrain 3 09-19-2007 02:53 PM
Just a teaser... rjspitz Titan Interior Discussion 8 04-24-2005 02:33 PM
Teaser pic of new wheels. QWIKWHIP Titan Pictures & Media Post 3 02-22-2005 11:21 AM
