OffRoadWarehouse Packages a 6" Lift for 4x2 COMBO KIT - Nissan Titan Forum
post #1 of 2 (permalink) Old 01-11-2017, 12:53 PM Thread Starter
Supporting Vendor
iTrader Score: 0 reviews
2004-2015 Nissan Titan 4x2 6" Combo Kit
Maxtrac Suspension 4" Spindles
Bilstein 5100's 0-2" front shocks
Bilstein 5125's w/bushing and sleeves
Maxtrac Carrier Bearing Bracket kit
Maxtrac 3" Block
Maxtrac U-Bolts/set
COMBO KIT #1 - $1020.00/Shipped!!!
See Parts list Below!
04-15 NISSAN TITAN 2WD 4" LIFT SPINDLES
PRODUCT SKU : #705340
Maxtrac Suspension's lifted spindles are a simple, but extremely effective way of gaining additional clearance in the front of your vehicle. By simply replacing your stock spindle, you can achieve an additional 4", while using stock control arms, springs and shocks. Maxtrac's spindles are made from Ductile Iron and are designed to be 100% bolt on with no modifications necessary.
  • Effective way of gaining additional clearance in the front of your vehicle
  • 4", while using stock control arms, springs and shocks
  • Made from Ductile Iron
  • 100% bolt on with no modifications necessary
  • Comes with teflon braided brake lines
SPECIFICATIONS:
Wheel & Tire Fitment:
17" Wheel or Larger with 5"" Backspacing or Less
Will Clear 33" Tire
Fits: 2004-2015 Nissan Titan / Armada4x2
Add a set of Bilstein 5100's 0-2"
A Pair of Rear 5125's with the CORRECT BUSHINGS
04-15 NISSAN TITAN CARRIER BEARING SPACER
The rear of the 2WD Nissan Titans require a carrier bearing spacer when being lifted 3" or 4". Without the Maxtrac Suspension carrier bearing spacer, your Titan will experience drive line vibration and other possible issues when accelerating from a stop. This kit is easy to install with instructions and all necessary hardware.
MaxTrac 3" Lift Blocks
MaxTrac Suspension has taken the generic lift block a step further. We fabricate our 3" and 4" lift blocks out of steel for strength. Then we powder coat our blocks for long life.
MaxTrac U BOLTS FOR 3" / 4" LIFT BLOCKS
Maxtrac 3" Block
Maxtrac U-Bolts/set
With Items above this should lift your Nissan Titan 6" and be leveled with the back
Some of the Nissan Titans encounter the Coil Buckets bending inwards over time, MORE noticeable on Lifted trucks when you can't correct the alignment to spec. Here's your solution!!!
Off Road Warehouse Combo Kit #2
Dirt King Fabrication Heimed Upper Control Arms
BEST for Maximum Lift and for Spindle or BRACKET lift kits, Having the Heimed Ends allows for PERFECT Camber/Caster corrections. When you are maxed out on your lower Cam bolts this is the BEST upgrade! it also $ave$ your expensive tires
Overview:
There are multiple issues when lifting your vehicle with stock upper control arms. Both the geometry and strength are compromised due to over articulating the UCA’s. We solved these problems by designing our arms with increased castor and repositioned pivot angles reducing stress on the joints. The increased castor allows for proper alignment and improved handling. We have also replaced the weak factory ball joints with 1” stainless steel uniballs for maximum strength along with increased articulation. For the inner pivots we used heavy duty FK heims for additional adjustability in the arm. To mount the arms to the spindle we include high grade 17-4 stainless steel misalignment spacers and grade 8 hardware. All of the components on our upper control arms are rebuild-able or replaceable to make this product last a lifetime. The arms come preassembled and include detailed instructions for easy installation.
• CAD designed upper control arms Maximum backspacing: 5.25" Vehicle must be aligned after installation
• FK 3/4" heims 2WD and 4WD compatible Appointments must be made in advance
• FK 1" stainless steel uniballs Major adjustability for vehicles with alignment issues
• 17-4 stainless steel misalignment spacers Designed to clear the coil bucket for maximum lift
• Grade 8 mounting hardware
• Durable black powder coated finish
#DK-701903Retail Price $650.00
Compatibility:
Nissan Titan 2WD/4WD 2004-2015
Nissan Armada 2WD/4WD 2005-2012
Nissan Pathfinder 2WD/4WD 2004
While ON the alignment rack getting your Heimed UCA's dialed IN, replace the stock OEM tie rod ends with stronger heimed rod ends. This helps tame those larger than stock tires giving you back instant and quick steering response.
Dirt King Fabrication Billet Heimed Steering
Have BIGGER than STOCK wheels and tires? Want to increase your Steering Response? This is a GREAT low cost upgrade. Dirt King Fabrication uses a High Quality FK Heims, 6061 Aircraft grade Aluminum tierods with provisions for EASY alignments & Grade 8 Hardware.
Overview:
Our heimed steering upgrade is a bolt on part that replaces the factory ball joints. Our tierods allow for easy alignment and major adjustment for vehicles with alignment problems. The heims give more articulation over stock and are perfect for lifts and highly abused trucks. These will work on all stock spindles with a minimum of a 17" rim. They will not work on lift spindles.
Includes:
-6061 aircraft grade aluminum tierods
-FK JM12T heims
-High angle misalignment spacers
-Tappered spindle spacer
-Grade 8 Hardware
#DK-701912Retail $225.00
Compatibility:
Nissan Titan 2WD/4WD 2004-Current
Maxtrac 3" Block
Maxtrac U-Bolts/set
Dirt King Fabrication Billet Tie Rod Ends
COMBO KIT #2 - $1800.00/Shipped!!!
Add-ON Options:
SPC 87520 x 2 = $50.00/set to Combo #1 or #2
Highly recommended if you don't already have adjustable CAM Bolts
These cams are designed to install in the lower control arms for camber and caster adjustment. They replace the original non-adjustable lower control arm bolts.
Front Adjustment range: Camber/Caster ±2.00°
Installation time: .3 hr/side
Required: 1 kit per wheel
Want this SPECIAL COMBO DEAL?? PM, Michael@orwmail.com or call ME 800-341-7757
Forum Board Specialist
800.341.7757
Customer Service is our #1 Priority!
We are the Nissan TITAN Experts!!
OffRoadWarehouse.com is a Brick and Mortar Business with 4 Retail stores with Installation and has been in the OFF Road Scene since 1973. We are DIRECT/Authorized with every Off Road Brand there is. With over 43 years of LOYAL service to our customers i can assure you that Customer Service is our #1 Priority!
OffRoadWarehouse is offline
Advertisement
post #2 of 2 (permalink) Old 01-18-2017, 02:48 PM Thread Starter
Supporting Vendor
Re: OffRoadWarehouse Packages a 6" Lift for 4x2 COMBO KIT
Thank you Titan Talk for your support, I hope i answered all your questions. Tracking numbers will be added soon and email to you. For those who DO NOT need the full kit as explained above you can pick and choose the components needed for your build. Have a great day!
800.341.7757
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
MAXTRAC Suspension Component Sale - 2-4-6-8" lift kit packages from TAP Auto Parts Chas M Titan Suspension 25 06-08-2016 02:00 AM
Will this lift kit, wheel set, tire combo plan work? aceckel Titan Suspension 3 02-24-2012 02:50 PM
FT: Pro Comp Stage 2 lift kit w/ 3" body lift and 37" Toyo MT/Moto Metal rim combo butcher43366 Buy/Sell 17 09-21-2011 08:44 AM
Anyone running 6" suspension and 3" body lift combo?? Pics if possible... quiksilver titan Titan Pictures & Media Post 17 12-26-2008 06:20 PM
4x2 lift kit advice Magdaddy Titan General Discussion 7 04-05-2007 08:54 PM
You may post new threads
You may post replies
